Reload this Page >
Balsa USA northstar
Balsa USA northstar
Old 06-05-2023, 04:38 AM
RICKSTUBBZ
RICKSTUBBZ's Avatar
Here’s something a little funny…
I was looking back at the BALSAUSA photo of the NorthStar sitting in the water.
....To put all the pieces together in my head while viewing your build pictures. Mostly, trying to visualize the elevator and engine mounting.
As I was looking at it I was thinking sure looks funny how it’s sitting in the water. Then I realized…It’s got wheels on it… LOL. They have it sitting in the water but standing on wheels…
I imagine if it was actually floating, the majority of the fuse would be under water and not make a good marketing photo..
With any luck we’ll get to see some pictures of yours floating in the water.
Old 06-05-2023, 05:53 AM
plumberdeluxe
My Feedback: (209)
plumberdeluxe's Avatar
Rick,
I never noticed the wheels in the water photo, but your right, they set the plane there to make it look like it was floating....
First off, yes I will take pics of the plane in the water, but I will first finish it, then fly it off land several times to get the c/g correct and dial it in.
There is no boat in my household, so I need to make sure it is completely ready once it hits the water.
I have 4 really nice lakes close to me and all would be excellent for flying this thing. I'm really looking forward to lake flying, kinda different but fun.
Last one I did for a guy was a blast on the water, flew very quick, and landed really nice.
This one I get to keep so I'm pumped about it.......................
Old 06-05-2023, 06:02 AM
plumberdeluxe
My Feedback: (209)
Here is the engine pod going together, I’ll leave the top of it unfinished until I mount it to the plane. The top is a 4” piece of balsa up front and the horizontal stabilizer in back. I’ll install the engine mount, install the pod on the plane, then add the top pieces once cables are attached.
Old 06-05-2023, 12:57 PM
plumberdeluxe
My Feedback: (209)
Well the entire build comes to this point. If there is to be any weird stuff on this plane, right here is where it will come from. There is a lot going on here during this step……. Once secure, all that is left is glueing on the tail feathers and mounting the engine. The level says we’re good but I have a goofy table that has me nervous……….
Old 06-05-2023, 02:19 PM
Outrider6
Thanks for starting this thread. Neat design, and you are a fast builder, doing good work. Definitely a "builder's kit", in that you need some skills, tools, etc., to get it done. A whole lot of thought went into that design. That kind of build is right up my alley, so I am enjoying seeing it come along. I have always been intrigued with BUSA's deltas, but never quite enough to take the plunge and try one. Maybe I will, after I get through with the 3 builds on my plate and forecast now. Probably a Force One, as I am currently building floats for the Javelin that I will soon be building.
It is pretty much the grey area of illegal (USACOE waters) to fly off of the lakes around here, but fortunately my club is able to get sanctioned float flies throughout the year, when there is demand for them.
Old 06-05-2023, 02:39 PM
  #31
plumberdeluxe
My Feedback: (209)
Thank You and I appreciate you popping in and watching the thing come together.
I have built several of all 3 of the BUSA delta planes. I really think any you choose will shock you at how fun they are from the moment you open the box. This Laddie guy must have been one hard core dude, his stuff is designed very well and every one fly amazing. I remember the first one of these I saw was at a float fly in Omaha/Council Bluffs and was instantly hooked, thus my interest in all the others. I will try to dig up pictures of some old builds I have done.
Here is a Force One I did for a buddy....
Thanks again, and hang around till the flying part if you are curious about these deltas.......................
Old 06-05-2023, 05:26 PM
  #32
RICKSTUBBZ
RICKSTUBBZ's Avatar
A few years back (well a little longer than that...this picture is from 2011) I was given a flying wing. Not sure if this one classifies as a Delta or not...
I put an old OS 45FSR and pipe on it..
I was really surprised at how well this thing flew. Only problem I had was I kept using the rudder stick to slide it around a little. That is wasted motion on this thing except when it's on the ground taxiing..None the less fun to fly. Awkward to get use to watching though. Currently it sets semi-retired... Needs a new covering job...
Laser Arrow circa 2011
Old 06-05-2023, 05:40 PM
  #33
plumberdeluxe
My Feedback: (209)
It is absolutely a delta, I bet it's a blast to fly, better get out the covering iron and freshen it up....
Old 06-06-2023, 04:37 AM
  #34
plumberdeluxe
My Feedback: (209)
Here is how much clearance I have with a 10” prop……..
Old 06-06-2023, 05:45 AM
  #35
Toto
Toto's Avatar
Looking very good can't wait to see the finish work and It should look great in flight Just waiting on the photos...
Keep it coming.
Old 06-06-2023, 01:16 PM
  #36
plumberdeluxe
My Feedback: (209)
Engine is mounted long enough to get the cowl made and shaped. I’m in a pickle as the only tank I have that fits the pod is only 8 oz. The plans say don’t go over a 10 oz but I want a 12 oz if it will fit. I have to drive to the hobby shop which will take most of the day before I can really move forward. I just don’t want to use a cheap plastic cowl or a dinky tank. Once I get this pod done I can start covering some pieces and keep moving…….
Old 06-06-2023, 05:30 PM
  #37
plumberdeluxe
My Feedback: (209)
Here is the winglet installed but not filled or sanded. I will do all the filling at once but not quite yet. The box is almost empty and the scrap pile is getting bigger. I’ll hit the hobby shop tomorrow and get my tank and a few other goodies. I think I have an idea for the covering scheme, so I’ll keep working on that also. Getting close………
Old 06-07-2023, 05:23 AM
  #38
plumberdeluxe
My Feedback: (209)
At this point almost all of the assembly is done with the exception of building an engine pod cowl instead of using the plastic thing in the kit. I’m going to get a proper tank today and the 3 remaining pieces (tail feathers) of balsa can be added. I’ll move from an assembly mode to a finish mode and prep the rig for covering. Things most likely will slow down as prep and covering a built plane takes more time than a component or two. Hang tight, this thing will be in the water soon…….
Old 06-07-2023, 05:25 AM
  #39
Toto
Toto's Avatar
Old 06-08-2023, 02:54 PM
  #40
plumberdeluxe
My Feedback: (209)
Here is the engine pod roughed in, I think this will be better than some plastic thing. Everything fits and I did get a 12 oz tank installed. I’m going against what the plans state to use, guess I’ll put the c/g farthest forward and have plenty of fuel to make several passes if I get into a mess. I think it will be fine, first flight should show any weirdness. I purposely am leaving the nose block off until last thing in case weight should be needed……….
Old 06-08-2023, 05:41 PM
  #41
plumberdeluxe
My Feedback: (209)
Well the construction is near complete and I have been able to make a few decent changes to the design with very few issues. Overall I’m happy with how things have went so far. These deltas are really unique and a fun change from most kits we all tend to build. The thing should last for years flown wisely. I’m ready to start to get some color on it. I have an idea that may look good…..
Old 06-10-2023, 08:30 AM
  #42
plumberdeluxe
My Feedback: (209)
Ok somebody let me know if this sucks……..and if I should rethink it. I have been thinking about doing this ominous German secret weapon concept. Basic yet highly visible with a kinda Red Max vibe to it. Second picture is what I’d like to somewhat end up with………with straighter lines
Old 06-10-2023, 09:08 AM
  #43
RICKSTUBBZ
RICKSTUBBZ's Avatar
LOL
No color scheme advise from me
I overdo just about every one of mine - so it seems.
You know, in the end, it's all about what it looks like for you... Your the one that has to watch it while you are flying it.
Now if you were building to sell to the "PUBLIC" what is it that they say? less is more...
Oh, I like that sketch...that is cool...
Old 06-10-2023, 09:27 AM
  #44
plumberdeluxe
My Feedback: (209)
The sketch is where I'd like to head, not too ugly, but just ugly enough...........
Old 06-10-2023, 01:13 PM
  #45
plumberdeluxe
My Feedback: (209)
Due the nature of this plane being completely assembled and the fact it sets in water, the covering will take quite a bit longer than a typical plane. It’s slow going but here is a start……
Old 06-11-2023, 06:29 AM
  #46
plumberdeluxe
My Feedback: (209)
A little more…….deciding to do the top first so I can make sure the bottom is sealed up as best I can……..
Old 06-11-2023, 11:16 AM
  #47
plumberdeluxe
My Feedback: (209)
A couple more…..amazing how long it takes to cover one of these planes.
Old 06-11-2023, 02:21 PM
  #48
plumberdeluxe
My Feedback: (209)
Wings are next………the thing feels pretty light as I’m covering it. I’m curious what it weighs without engine and gear. Finished weight is around 6.5 pounds I think…….
Old 06-11-2023, 02:55 PM
  #49
Toto
Toto's Avatar
I was out but i like the scheme..
Old 06-12-2023, 05:48 AM
  #50
plumberdeluxe
My Feedback: (209)
Thanks Toto, appreciate the input…….I got 1 wing panel attached, I’ll do the other side and then add the white stripes and the Maltese crosses. This is a tough cover job make no mistake, and the reason for my simple cover scheme……..
