Reload this Page >
Skymaster 1:7.5 F-4 Phantom
Old 12-14-2021, 07:11 AM
  #326
YellowAircraft
Originally Posted by kevinthoele
I used UP valves for gear. I did have 5 connections but doors stay shut during flight
What do you mean? Like they cycle closed after deployment?
Old 12-14-2021, 07:12 AM
  #327
YellowAircraft
Guys,
Please share your installation pics (under-cockpit in particular). I'd love to see how you all placed your equipment.
Old 12-14-2021, 07:24 AM
  #328
kevinthoele
no doors stay open gear down. But the don’t open during flight with gear retracted. Some are saying they have issue with that. Those have added rare earth magnets that click door closed to help with air flow opening
Old 12-15-2021, 09:25 AM
  #329
YellowAircraft
Hi,
Ah, ok. I see. Are people having that problem due to airflow over the door opening them or pressure from inside? In the past, I've built little 'ramps' or 'spoilers' to aerodynamically push the door closed. They were pretty diminutive, and unless you were a crew-chief on the FS, you wouldn't know they weren't scale. On a bigger plane, I even made some that was basically an inverted airfoil about 1/4" wide, sandwiched between two 1/16" ply vertical walls about 1/4" tall. The whole thing was a 1/4" cubed and looked like some kind of raised intake grill. Kept the doors closed tight at speed, but relaxed enough when you slowed down as not to be an impediment to the rams opening the doors.
Old 12-15-2021, 09:40 AM
  #330
YellowAircraft
Originally Posted by yeahbaby
Mike does the Matrix guy actually answer the phone?
Buck!
How the hell you been, buddy! I thought about you the other day. Somebody was flappin' gums and I didn't feel like arguing so I smiled and did a Buck and said, "Ok, lil' fella."
Old 12-15-2021, 01:20 PM
  #331
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Buck!
bwwaahhaaaa works like a champ doesn’t it? Lol. Doing great amigo. Hope everyone is well.
Old 12-16-2021, 12:18 PM
  #332
kevinthoele
Hi,
No unlike planes that have doors in fuse that have pressure, the wing doors are in wing and dont receive any pressure
Old 12-16-2021, 05:53 PM
  #333
YellowAircraft
Hi,
Yeah, I get that. The ramps I mentioned worked in either case. BTW, do you happen to have any install pics of yours?
Old 12-17-2021, 04:21 AM
  #334
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Default Install
Guys,
Here is my install under the canopy. I did mine so that the cockpit doesn't have to come out at the field when servicing and flying.
Mercury SRS in the center. Flanking it with EvoJet dual valves for retracts and doors.
EvoJet dual Brake valve. This valve is true proportional with single air line from the valve to it's respective side.
The Jetronic single valve is for the chute
Old 12-17-2021, 04:31 AM
  #335
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Default Engine compartment
As I mentioned in the previous post. I don't want to remove the cockpit when at the flying field.
Notice the Master "Locking Bat Switches". These switches are used in full scale. Top row from left to right. #1 Battery, Engine Battery, #2 Battery. Bottom row left to right is; Smoke Battery, Lights. The two fueling station is smoke and fuel. Air gages and valves for brakes and gear. The the PB switch and screen. I only use the PB switch for programming. Otherwise it stays ON. The Bat switches are the Masters.
The carbon fiber look is the fake plastic laminated to G10 for strength. Then the whole panel is fastened with heavy duty Velcro.
Old 12-17-2021, 10:20 PM
  #336
YellowAircraft
Thank you!
Interesting setup. Where did you get that bell-mouth? I like the idea of not having to remove the canopy to service the plane for flight, but I think it may be too late for this one.
Old 12-17-2021, 10:33 PM
  #337
YellowAircraft
Guys,
With the stock pipe, I've read that the bend should angle downward. This one has a written 'UP' indication on the 'top' of the pipe, but the exhaust side is definitely not thrusted downward. What's the scoop on this?
Old 12-18-2021, 05:01 AM
  #338
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Thank you!
It's a Tam's pipe and the bell came with it. Most cockpits are too delicate to continually remove at the field. So they get tore up. I do all of my installs so that I don't remove the cockpit.
The Tam pipe doesn't have the up or down bend in the pipe at the rear. I have the engine and pipe tilted down a good 5 degrees. The exit of the pipes are as low as can exit the exhaust cones.
Old 12-18-2021, 06:13 AM
  #339
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Default In action
This past week, I was fortunate enough to fly with Marvin from Miami. Besides an excellent pilot, he is an excellent photographer.
Off on a mission
This was a real low pass
I thought it was neat how he caught it turning into us. He gave me directions on how to come in on one runway, fly and arc around us, and exit the crossing runway.
Gear check.
The following 2 users liked this post by RCFlyerDan:
Halcyon66 (12-20-2021), yeahbaby (12-18-2021)
Old 12-18-2021, 06:55 AM
  #340
YellowAircraft
duplicate
Old 12-18-2021, 06:58 AM
  #341
YellowAircraft
Hi,
Those pics look fantastic, Dan!
Old 12-18-2021, 07:54 AM
  #342
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Hi,
Thanks! They have amazed me! I just can't get over how much it looks full scale. He has an amazing eye for the camera.
Old 12-18-2021, 09:07 AM
  #343
YellowAircraft
Hi,
I don't suppose anyone has a set of main gear doors for this bird laying around?
Old 12-18-2021, 01:15 PM
  #344
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Welcome to club Rhino amigo. Great job on your bird.
Old 12-19-2021, 08:00 AM
  #345
Kevin_W
Guys,
I used the Skymaster pipe and mounted it upside down. The thrust angle appears to match the full scale pretty closely, and I haven’t experienced any pitch changes with throttle.
Old 12-19-2021, 09:40 AM
  #346
kevinthoele
Shaun
mount the pipe upside down. You need 5 degrees down angle on pipe
Old 12-19-2021, 09:19 PM
  #347
YellowAircraft
Shaun
Thanks, Kevin. That's what I did!
I got the hook working tonight. Positive up tension, but a spring-loaded deal on the down side lest ye bump the deck with it.
Old 12-20-2021, 11:42 AM
  #348
YellowAircraft
Hi,
Any of you guys dress up the exhaust area? I've been looking at some of the dazzling airbrush work on plastic models with metalizers and burnt this/burnt that. I'd love to see what you guys have done to yours.
Old 12-20-2021, 11:50 AM
  #349
Halcyon66
Those pics are awesome.
Regards,
Old 12-21-2021, 02:45 PM
  #350
YellowAircraft
Hi,
Welp... first attempt, so not awful in my opinion. Not sure if I should leave it alone or keep trying to tweak it.
