Jeti assist reciever
#126
Good news regarding the issue of Assist receivers sending out stabilized EX bus signals even without receiving TX signal.
Today I've received an e-mail from Jet stating that they are fully aware of the Assist receivers giving out signals even when there is no reception from the transmitter. This will be fixed in the next update for the Assist receivers. Release is expected around end of february (maybe March).
#127
My Feedback: (10)
Well I found another thing the Assist won't do and that is stabilize UDI output. Since they have a separate"Stabilze EX Bus" control for the Central Box I'm not surprised but I had hoped it would. Hopefully at some point Jeti will update the firmware to stabilize either UDI or EX Bus output so that it can be used for power expanders like Power Boxes or my XPS24 instead of just the Central Box.
we make a 2 port and a 4 port expander for jeti EX bus to Servo
this little device can expand your 7 or 12 channel assist to 11 or 16 channels stabilised.
read more here : http://www.rcuniverse.com/forum/rc-j...ts-%2A%2A.html
#128
My Feedback: (7)
Hi Wayne
#129
FL
Hii all,
I've tested new Assist12 receiver with my electric Me163(Delta scheme)
The result was very horrible !!
Suddenly lost response of only aileron and when operated elevator it recoverd response many time of test flight.
i've check the flight log of Q value, it was fine.
i guess this system have some soft bugs yet.
#130
SC
I have less than a dozen flights with a rex7a to date but will be installing a rex11a in a new F16 soon. Wonder if problem is isolated to the larger channel Rex assist rx?
#132
FL
Yes, same exact issue
Mine was calibrated, working fine
On the 3rd flight, suddenly the plane made several spiral rolls, I throttled back and when I pulled it suddenly stabilized. when I let go of elevator it would roll again
I also had a switch on/off as suggested, it stopped working.
happy flying
George
happy flying
George
#133
FL
Another issue, here are my settings:
In mode 1, normal mode, only ailerons (all others are X out). Gyro seems to control only ailerons (which is what I want for testing)
In mode 2, normal mode, only elevator (all others are X out). Gyro definitively is also acting on ailerons ??
In mode 3, normal mode, only rudder (all others are X out). Gyro definitively is also acting on ailerons ??
Am I missing anything, this setting should allow me to test only one axis at a time
#134
SC
George,
Thanks for the follow up. Now I’m really concerned and will have to come up with another plan for my new model. I would have thought turning the gyro off would work as a bail out plan.
Since my plan was to use a Rex 10 assist (not a 11 as I listed above), our equipment is not exactly the same but still raises concern. Perhaps I’ll pull the Rex 7A out of my test bed plane (cheap foamy) and install the 10 assist to see if I can duplicate your issue.
Would you you confirm your wing type? Delta, 2 ailerons/2 flaps, tail type?
Thanks!
John
Thanks!
John
#135
I would suggest contacting James at Esprit Tech he can help you to setup Assist receiver correctly. We tested all of them, they work fine but you have follow certain steps.
Also here we started official Jeti Assist thread
https://www.rcgroups.com/forums/show...gramming-Telem
#137
Test flew a Rex7A in a Sports Glider in 35kmh wind and it performed great. Have now installed a Rex10A in my 1:6 F16 CB200 and Rsat in Double Path. Finished the setup and all is doing what it should.
#138
Hi Friends,
Sorry for posting my issue in this threat which might not be relevant.
I have DS 16 + R14 Receiver + RSAT Receiver. I wish to bind both receivers in Dual Path Mode to have redundancy for all the channels. These receivers are installed in a BVM Bandit. I need detailed procedure how I can accomplish this task i.e Binding both receiver in Dual Path to have redundancy for my Jet.
My Feedback: (10)
Hi Friends,
My Feedback: (53)
Hi Friends,
Jeti Video
no need to be rude.......
#141
hello guys.
So far I have a mixed feeling with the assist receivers....
I set-up a rex7a in a 3D foamy and that seems to work fine.
I also set-up a rex12a in a sportjet and that is a complete different ball game and so far not usable for jets!!
Somehow the assist can't handle with mixers, flight modes and maybe trims on "separate" as well.
Scenario1:
I use 3 flight modes (start-cruise-landing). On "landing mode" the flaps will go down, aileron up (crow) and elevator compensation. The "assist" sees this as "stick input" as I can see this in the "primary channel assignment" menu.
This is of course completely wrong. What happens is when in landing mode and switching assist on and off, the flight controls surfaces jumps with sticks in neutral.
Scenario2:
In menu "function assignment" I made a function "nose wheel steering" with trim control on P8. In menu "free mixes" I made a mix "rudder to nose wheel steering". When gyro off, the P8 trim works as it should be, affects only the nose wheel steering! When gyro on, the rudder is also affected when turning P8. Very very strange.
So far this is what I discovered and who knows if there a more bugs in the assist rx!
Does anyone have more luck in setting up there jet?
Scenario1:
Scenario2:
#142
My Feedback: (7)
hello guys.
Scenario1:
Scenario2:
Scenario1:
Scenario2:
As for the Nose Wheel Steering (NWS), I suspect the Assist treats all controls tied to the Yaw axis as a single function as far as stabilization goes so if the center on any control stabilized by the Yaw axis changes then all other Yaw axis controls get affected as well. If that is the case, I would think disabling stabilization on the NWS function may solve the problem with the rudder shifting with NWS trim.
I'd be curios to here more if you decide to experiment further.
#143
hello guys.
Scenario1:
Scenario2:
Scenario1:
Scenario2:
#144
When you say flight controls jump when you turn the Assist on/off with in a flight mode with elevator compensation, which controls ? I would expect that if the only change is elevator compensation, then only the elevator would move. Do other controls move as well ? Does it behave properly (elevator smoothly moves to new position) if you leave the Assist on and simply select a flight modes with elevator compensation ?
As for the NWS, you might be right. I think I tried all the scenario's and don't have any idea's anymore to get this working. Hopefully somebody else is giving it a try and maybe my rex12A is just a bad one but somehow I have the feeling it is just wrong software.
#145
Have Assist Rx's in 3 Turbine Jets so far and all working perfectly. One of the jets is a 1:6 F16. I use only Dampening mode.
The issue with Trim dial affecting rudder appers when your Yaw Calibration is out. Even if its only a few %. Whenever trim is changed in flight, calibration of sticks is required.
#146
I use 3 flight modes (trims separate).
-take-off mode: different dual rates, expo's, flap 10 degree's, elevator compensation
-cruise mode: different dual rates, expo's, flaps up
-landing mode: different dual rates, expo's, flaps 45 degrees's, elevator compensation, CROW
I fly jets for more then 10 years this way. If you say calibrate stick? In which mode you mean? In my point of view you ONLY can calibrate sticks in ONE mode.
#147
My Feedback: (7)
Good to hear you have succes with your assist receivers but I guess I can't explain my problem properly.
#148
My Feedback: (10)
I think philjac94 is on to something as far as the NWS goes. It does look like the Assist simply doesn't tolerate ANY trim changes on any control on any given axis. In other words, you would need to trim your NWS to steer straight on the ground with the Assist OFF, then lock that setting down using sub-trim, etc and then disable the trim function and re-calibrate the sticks. I don't see this as being a particular problem as I've been doing this with the Aura 8 for quite a while now and once I learn the new centers and re-calibrate, I've never needed to change the trims again. The Aura however tolerates minor trim changes for things like elevator compensation, knife edge mixes, etc, without any problems at all. In order to be useful in anything other than simple sport models the Assist will also need to be able to tolerate minor mixes and trim changes required for flap deployment, etc. It doesn't sound like it's there yet which is a bit disappointing as this is a pretty basic requirement for things like Jets and warbirds which make up a huge part of the market that they should be targeting.
I think the nosewheel is Didiers least of all problems.
like he said you can not even use Crow or Down elevator on a Flightmode switch, since it counts as a stick input.
so it will not work...
#149
I don't know if it is technically possible but to solve this problem is to send raw stick input data (from hall sensors) to the RX as well or give the possibility to calibrate sticks in every flight mode and assist mode.
#150
Didier,
If, after recalibrating the Yaw Control you find that the rudder continues to move with P8 trim, then I would recommend that you go into Free Mixes, delete the mix and then reinstate it.
Hopefully, this will fix your problem.
