Jeti assist reciever
Hii all,
I'm Jeti DS16 user and also very interesting in new REX assist receiver.
Very simple question.
Can new REX assist receiver work on my transmiter too?
My Feedback: (7)
To be honest I like Dansy’ suggestion of a cb400 better than extra receivers..
The 12ch assist Rx has only one high current MPX connector, if we want to use a second battery plugged into a RX or a switch where will this go?
Most power safe Rx have dual deans or MPX connectors.
Thanks Chatty.
Thanks Chatty.
My Feedback: (7)
Jeti also offers a voltage regulator with dual battery inputs and a magnetic switch into a single output if you need voltage regulation for your servos.
Emcotec also offers dual battery input switches which have a higher current rating if needed but also have a higher price tag.
Basically and battery share circuit / switch which you feel meets the current demands of your airplane.
If you feel you need high current capacity then perhaps a Jeti Central Box with one of the smaller Assist receivers (R7 Assist) in place of the R3 or RSat primary receiver.
personally I would use something other than an R3 as the primary and connect extra servos to it rather than a clone. If you connect any servos to a receiver connected to a cb200 you MUST provide additional power to the receiver or you’ll destroy your cb200.
My Feedback: (7)
I look forward to hearing what you think of yours as i'd like to try one once they are available here.
