Xicoy - LG15 Gyro Controlled Brakes
#404
NJ
Yes Battery connected, I think its a bad unit, tried different pin position on gear out, with volt meter between gear and controller and cant get any voltage reading coming out no matter which way I use pin set up.
#405
Have you tried using the MAN EXTEND/RETRACT method to test the retracts? I would recommend resetting the unit to factory settings, then try MAN EXTEND. If you do this and the gear work, then the problem is likely in your gear door sequencer settings. -Tom
#406
NJ
Yes, Tried that also, no action, how do you do a factory reset, I'll try that, If that don't work, then its for sure done, brand new to, that sucks, but, like you said, maybe hooking a servo to it did something, not sure. maybe it back fed power through signal wire some how, beats me.
#407
NJ
I could, But I know there right, using standard JR connector with negative in bottom pin and positive in middle pin, tried moving positive to top with negative in bottom, still no action, no matter what, I cant get any voltage to come out the gear side, servo side is fine, shows voltage on all servo connections,
#410
A servo clearly will not work. Servos have three wires. Landing gear operators have two. On my prolink gear operator, the ground is in pin 1 and the power wire is in pin 3 (i.e. normally where the signal wire is). The gear operator's connector may be configured wrong if its connector has a wire in the center position of the connector. If the gear operator's wires are in Pin 1 and 3 then plug the connector in so that the wires are reversed. Or if the wires are correct in the gear operator's connector. It could be trying to drive the gear operator against the stop and the current limit is being reached. Also, the current limit setting may need to be increased enough to drive the gear. Again, a servo will not work as there is no signal being sent to it.
#411
NJ
OK, Next problem I'm having, NO Steering, Using Aux 5 on receiver for steer in to the lg15, mixed to rudder in transmitter. If I pull the steer in lead out of the receiver and plug the steering servo straight into the receiver all works fine, so I know its receiving a signal to steer. But running from aux 5 to steer in on controller, then hook servo to steer out on controller, it don't work, so I know the transmitter is sending steer command to controller, but the controller is not sending steer command out. I zeroed out all the gyro setting in controller to see if that was set up wrong, but still cant get the steering to work when using LG15, only works when steering servo is connected direct to aux 5 on receiver. Any Idea's ?
#412
My Feedback: (53)
Yes your switch is down and the gear is down...but the controller is up
a quick test switch the gear up and try the steering....
#415
I have a LGC-13. It was working okay but the gear was down and the controller said they are up. So I started to try and change settings. I'm using the screen form my X45. Not it don't work.
Is there a way to reset it to factory settings? I cannot figure out how to scroll thru the menu and change things. Its not user friendly. Why cannot it be plugged in to a computer? Is there a better controller?
I'd switch to the JP controller I have but then I have to redo all the wire ends.
#419
#422
I heard back from Gaspar, I’m always amazed at how quickly he responds
There is no “factory reset.” He said you can copy the config from another unit and load it though. If someone has one new that they have not yet programmed they could save their settings to a microSD card and that could be used to effectively reset to factory settings. If not, I’d be happy to share my settings file. -Tom
#423
My Feedback: (53)
[QUOTE=Tip22v;12641633]I heard back from Gaspar, I’m always amazed at how quickly he responds
There is no “factory reset.” He said you can copy the config from another unit and load it though. If someone has one new that they have not yet programmed they could save their settings to a microSD card and that could be used to effectively reset to factory settings. If not, I’d be happy to share my settings file. -Tom[/QUOTE
Theres something I don’t understand....as far as I know you cannot used the LG13 because it’s not programable by the user like the unlock LG15?? And there’s no sd card on that one??
#424
[QUOTE=Dansy;12641636]
I’m assuming that the original poster meant LGC-15 based on how he was describing his issue, and because this thread is only about the LGC-15. Perhaps that was a bad assumption, can the guy with the issue confirm his unit has a screen and is in fact an LGC-15, and not an LGC -13?
