Xicoy - LG15 Gyro Controlled Brakes
#426
Okay, please disregard my comments, I falsely assumed you were referring to a Xicoy LGC-15. -Tom
#432
NJ
‘I know why...I have encounter that before.......the LG15 stop the steering with the gear up...and right now it knows the gear is UP, do a relearn...
Yes your switch is down and the gear is down...but the controller is up
a quick test switch the gear up and try the steering....
#434
NJ
Still no steer, went through everything, got switch set up for the position I want for gear up and gear down, which matches the controller when it shows gear up and gear down. no steering in either position. receiver is sending out the steer command to controller. tried different servo to be sure and still cant get a steer command out of controller. Now what?
#435
My Feedback: (53)
#436
Has anyone compared the LGC-15 to the Digitech CRU? I am currently operating three Xicoy LGC-15 units and recently purchased a Digitech CRU for comparison. At first, the DigiTech was a little intimating as there is no onboard screen, but that is not a problem if you are using Jeti because all the programming is done via the Device Explorer. The length and width of the two units are the same, the LGC-15 is a few mm more in height. I have not actually flown the Digitech CRU yet so I will reserve my opinions on the performance of the CRU until after my first few flights with it, I will say that taxi tests with the unit look very promising. Overall, so far, I'm very impressed with the Digitech CRU unit as it has many PROS over the LGC-15 if you are using a Jeti radio. If my test flights go well with the CRU I plan to replace all of my LGC-15 units in the near future.
Here are my PROS/CONS for the Digitech CRU so far:
PROS:
-If you use Jeti, programming is much easier and more convenient using Jeti Transmitter
-CRU is slightly smaller (in height)
-CRU is $50 less expensive
-CRU has option for Nose wheel brake (I don't use this option, but it's there if I needed it)
-CRU can send telemetry info to Jeti, can setup alarms for stuck gear doors etc.
-CRU works with only a single cable from the receiver (EX Bus) for gear signal, rudder signal, and brakes signal, and it's very easy to configure in the device explorer. Fewer wires for cleaner installation. I think the LGC-15 has this capability as well, but have not tinkered with it.
-No screen calibration errors to deal with like on the LGC-15, which seem to happen frequently.
CONS:
-The computer software needed to update the firmware is not very intuitive, although I was able to figure it out after only a few minutes of tinkering.
-If you are using a transmitter that does not have Jeti Device Explorer type capability I would not recommend the CRU because programming would presumably require a computer.
PROS:
CONS:
#437
PROS:
CONS:
PROS:
CONS:
#439
#440
as for mounting, you can buy their 3D mounting bracket or you can make your own with a piece of 1/16 plywood and some two side tape (I made my own).
#442
PROS:
CONS:
PROS:
CONS:
I'm sorry about the "Programmer" application that is used for uploading new firmware to the CRU, you are right, its not very intuitive. Its a program I use for many other embedded projects/systems I have made over the years, so it was a way of saving some development time.
Regarding using the CRU without Jeti, that's not gonna happen in the near future. There are so many feature to setup in the CRU that it would make for a somewhat complex application. A good example is the gear door sequencer, when you program that, you do it interactively. And it is SO much easier doing it from the transmitter than to have to do it from a PC.
So for now, and for a long time, its only JETI
PS: I'm the developer of both the hardware and software for the CRU and a "few" other things
#443
Thanks for the nice words
Thanks for clarification, I was not sure about how it would work without Jeti. No worries on the firmware updater program, once I figured out how to update the firmware it was pretty easy. I think you did a really good job with how the brake functions are organized in the Device Explorer. I have not tried the retract or door sequencer programming yet, but I'm confident it will be as straight forward as the brake settings.
I do have a question for you: in the LGC-15 you can select Heading Hold for Gyro Braking as an option (verses Rate Mode), I have not found a way to do that in the CRU, is this an option with the CRU?
Thanks again- Tom
#444
Carsten,
Thanks again- Tom
Thanks again- Tom
regarding the gyro, only rate is supported in the firmware.
To be honest, the door sequencer is (almost) the thing I'm most proud of, it shows brilliantly why Jeti in combination with the device explorer (and a device that is supported by the device explorer) is such a fine combination
Regards,
Carsten
#445
Hope I can get some help
Having a hard time setting up the T-1 mini again. This time my Futaba 14 channel receiver had two ports that were not working so the LG-15 was not recognizing the brake setup. Now I have the brake wire in my DG1 input and it is working now. I had the two channel setup but now when I cycle through all the options it is gone. I see one channel, Futaba S-bus etc but not the two channel option. It is currently set to one channel. All my control surfaces work, retracts, door, and now brakes. What's the difference between the one channel and two channel RC setup? I got the PNP from Dirk. Kinda wishing I saved some money and just built it myself, servos not centered before horns put on and stuff like that. How many mm of down elevator are you guys mixing in with half and full flaps?
Thanks again,
Matthew
Thanks again,
Matthew
#446
My Feedback: (53)
Thanks again,
Matthew
Thanks again,
Matthew
For the mixing I’m not sure, but I’m sure the futaba can do single flight mode trim...that’s the way I have it on my TX .....first flight I put the flap to T/O adjust trim full flap adjust trim and it’s set for life.,,,
#447
Still struggling
Need some help with how to use the LG-15 with a power box product such as the Pioneer. I removed the deck from the T-1 mini so I could see what was what etc. I did not see that the two JST type leads that power the receiver where just connected to the main battery lead that feeds the MPX connector to power the retracts and brakes. I have been reading the manual more and understand now that the computer part of the LG-15 gets its power from the gear in signal wire from the receiver. Do I need to have both of those JST type power connections plugged into the receiver? How many batteries do I really need to power this? If I had a battery for Turbine, 2 for the Pioneer, and one for the retracts / brakes that would be four etc. Is there a better way to wire this up? I disconnected everything and then reconnected to make sure I can do it, but I am confused how to make this better. I would like to run two receivers and not have to use four separate batteries. My 12 channels receiver is not helping as I have a 16SZ, the SRS expander and the Gemini II are other PB products I have been looking at.
Thanks in advance,
Matthew
Thanks in advance,
Matthew
#448
My Feedback: (53)
Not 100% sure I understand, so I will just try to explain what I do....
I only used 2 RX’s batteries and 1 ECU.....I always connect the Gear controller to the #2 battery, of course the normal connection like GEAR/BRAKE/STEERING/DOOR as well...in doing this the door and steering are actually power by the RX connection while the retract and brakes from the #2 battery....
