Reload this Page >
TopRc Voyager build
TopRc Voyager build
Old 03-17-2020, 06:14 AM
David Jackson
My Feedback: (15)
Nearly had one in my collection of toys, but discovered major damage to the model before taking it from the delivery truck. So still interested in this model, especially the new military paint scheme.
Old 03-17-2020, 06:53 AM
sysiek
My Feedback: (176)
sysiek's Avatar
I do like that one too, just wish that the yellow will be changed to gray the full wings or maybe something like the f-100 Vietnam era green brown camouflage , this model will look great in all types of military paint jobs.
Old 03-20-2020, 06:55 AM
vquick
My Feedback: (71)
vquick's Avatar
I have the new tank from Top Rc Models if you interested i can sell you this one $100.00. I'm using the kevlar we made in mine also
Old 03-20-2020, 07:21 AM
sysiek
My Feedback: (176)
sysiek's Avatar
Please post the picture of the new style fuel tank thanks again
Old 03-20-2020, 11:46 AM
vquick
My Feedback: (71)
vquick's Avatar
this is the tank
Old 03-21-2020, 01:27 PM
  #31
GULDUKAT
Originally Posted by vquick
this is the tank
Capacity?
Old 03-21-2020, 01:33 PM
  #32
vquick
My Feedback: (71)
vquick's Avatar
5 liters
Old 10-05-2020, 01:50 PM
  #33
FCruz
My Feedback: (12)
Is it available in Kevlar?
Old 10-05-2020, 07:52 PM
  #34
sysiek
My Feedback: (176)
sysiek's Avatar
My new version has two fuel tanks the exact same line the picture, actually I wish they made those from plastic like jet legend jak 130 this thing is actually very fragile and very thin.
Old 10-05-2020, 09:24 PM
  #35
bodywerks
bodywerks's Avatar
I watched Santiago Perez fly the piss out of one of these. GREAT flying jet.
Old 10-06-2020, 03:49 AM
  #36
GULDUKAT
Default Maiden and thoughts
22.5kg dry.
6.5L fuel
3.5L smoke
K260
Bluebird H51B x 8 servos
I put 3 flights on this thing. It flies great. Definitely needs a lot of Crow to slow it down with K260. Knife Edges quite well even at low speeds. Low and slow is quite predictable. No bad tendencies detected yet.
must do's:
Get flaps geometry correct for reliable flaps operation.
If you use stock gear with stock Springs then do not modify them.
Old 10-06-2020, 06:24 AM
  #37
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Nice Jet. Sleek look and the scheme suits it well.
Old 10-06-2020, 06:30 AM
  #38
sysiek
My Feedback: (176)
sysiek's Avatar
I think the problem with slowing down is that the cg is way too nose heavy, the manufacturers recommendations is 280mm from leading edge but it’s actually right in front of the wing tube at 13” from the edge, this military one flying good and slow down very well and landing slow with jet central mammoth
Old 11-01-2020, 02:55 AM
  #39
GULDUKAT
The following 2 users liked this post by GULDUKAT:
millsy14 (12-25-2023), skunkwurk (11-23-2020)
Old 11-01-2020, 05:58 AM
  #40
sysiek
My Feedback: (176)
sysiek's Avatar
This is my with the same paint job, the cg is right in front of the wing tube, only two flights so far, the first with almost manufactured recommended cg and the second flight with 13” cg and the third will be with the cg right in front of the wing tube
Old 11-22-2020, 10:26 AM
  #41
David Jackson
My Feedback: (15)
Curious, how well would a 220 size powerplant fly this model? Planning to sell the airframe, so the 220 will need a new home.
Old 11-22-2020, 11:06 AM
  #42
sysiek
My Feedback: (176)
sysiek's Avatar
Should be fine for regular sport flying,but most people after some time change it to 250-260 size motor, I’m doing ok with the p-200 even the motor have so problem to not reaching the maximum rpm to 112.000 it only goes to 109.000 and produce only about 205 Newton instead of 230n like the p-200sx should do , one guy flying this model with sw160 and he is doing very well maybe very light build?
Old 11-22-2020, 11:07 AM
  #43
sysiek
My Feedback: (176)
sysiek's Avatar
Old 11-23-2020, 01:57 AM
  #44
GULDUKAT
I have about 30 or so flights on mine with the K260. A 220 is more than ideal. It is not a very fast airframe - so the extra power is not going to make it go any faster. It draws some of the best line and KE is a breeze. Got some videos from yesterday - will post them shortly.
Old 11-23-2020, 07:36 PM
  #45
jeteye
Originally Posted by sysiek
So today some rear servo cables, I’m using high temperature resistant tube to cover the cables from possible heat from pipe if something happens at least this will help to have some extra time to maybe have the jet landing safely, maybe because I have seen some jets goes down because some of the cables got in contact with the pipe and the rest what happens you know,
Where did you order this protective covering from; thanks.
Lewis
Old 11-23-2020, 07:44 PM
  #46
sysiek
My Feedback: (176)
sysiek's Avatar
I’m trying to copy passed the information but the rcuniverse blocks the information
Old 11-23-2020, 07:45 PM
  #47
sysiek
My Feedback: (176)
sysiek's Avatar
Ebay has everything and so much different sizes
Old 11-23-2020, 08:37 PM
  #48
sysiek
My Feedback: (176)
sysiek's Avatar
https://www.ebay.com/itm/1-40mm-Whit...-/153050276433
Old 11-24-2020, 12:16 AM
  #49
GULDUKAT
jeteye - what type of servo wiring are you using?
Any link to where you get those from?
22awg or 20 awg?
Copper strand or steel?
Old 11-24-2020, 06:47 AM
  #50
sysiek
My Feedback: (176)
sysiek's Avatar
https://hobbyking.com/en_us/800mm-tw...-5pcs-bag.html most of them are from them with different length and 22 awg the price is right and I never have any problems with those
