ESM Dornier DO 335
#101
My Feedback: (19)
MN
RE: ESM Dornier DO 335
ORIGINAL: fockewulf37
Well I am finally Getting started on the interior of the Do335. This thing going by wing span is about 1/6.5 scale. The 1/6 scale German pilot will be a perfect fit.. I have made the first cuts to the fuse. there is plenty of room for a full cockpit for this one..I discussed something with Darrell when i was installing the nose gear. He pointed out there is nothing but fiberglass supporting the nose section of this plane. Anyone putting a large motor in the nose should consider reinforcing this area. I am going to recommend it if you decide to put a cockpit into the plane. It would be really easy to do.
You could either use carbon fiber glassed onto the insides or since the wiegh is not an issue I would just use 1/8'' balsa that fit tightly between the bulkheads and glass/glued to the interior sides...
But think about the stress of a 50cc motor and landing gear all in the nose.... Maybe not an issue as we all tend to over build anyway....
Ty
Ty
What would you or Darrell suggest to reinforce the nose section? More fiberglass? Wood or carbon fiber formers running from firewall back?
The front end seems solid to me. One possible problem would be that the firewall is not glued in properly -looks like they just put a
bead of glue around the perimeter of the firewall on the front side. I can't tell if there is glue in the actual joint.
Brian
#102
My Feedback: (102)
Personally I am putting a cockpit in the one I have. Before I install it I will just reinforce the area with some 1/8" balsa glued/Epoxied to each side . Maybe a 4" wide piece that has been cut to exactly fit between the bulkheads. That will really strengthen the area. You could also use some carbon fiber glassed into the sides.. That bead you see in there is a bead of fiberglass and something like cabosil It should not ever move...
Ty
Ty
#103
My Feedback: (19)
MN
Personally I am putting a cockpit in the one I have. Before I install it I will just reinforce the area with some 1/8'' balsa glued/Epoxied to each side . Maybe a 4'' wide piece that has been cut to exactly fit between the bulkheads. That will really strengthen the area. You could also use some carbon fiber glassed into the sides.. That bead you see in there is a bead of fiberglass and something like cabosil It should not ever move...
Ty
Ty
Yes, I tried to grind out some of that stuff in one spot and it was really tough. It has fiberglass strands in it.
It sure would have been easier to put carbon fiber or wood reinforcement strips down the sides if it were done before the bulkheads went in! Then it would have tied into the bulkheads at the nose gear area and the firewall area and at the wing area with one unbroken piece- it would have been super strong. I will do what you are doing - put reinforcing material between the bulkheads on each side.
By the way, the fuselage is made with polyester resin (I can tell by the smell when I cut it), which I use as the glue to glue anything to the fiberglass fuselage. I did a test on a piece and it holds much better than epoxy glue. I did the same test about 30 years ago when some of the planes had an epoxy base and some had a polyester base - with the same results. For the polyester ones, polyester resin holds much better than epoxy glue. I am using Bondo from the local auto parts store, but the stuff Sig sells at the hobby shop is fine also. And you can control the setting time with the number of drops of activator.
Brian
#104
My Feedback: (19)
MN
I have an ESM DO-335 and have been working on it for a couple of weeks. I'll send in posts of my progress that might help someone else or me.
Since no one has flown one that I know of, and ESM and its dealers do not have any video of it being flown, I am initially going to build it "on the cheap". By "on the cheap", I mean I will not be investing any more than is needed to safely first fly it. When it flies and flies decently, I will finish it up. I already own the engine and radio components. So my expense will be the cost of the ARF, and probably about $100 - $150 for hardware (I expect to use little or none of the hardware that comes with it - I hardly ever do with ARFs).
I will be initially building it with fixed gear. After it flies, I will buy the Sierra retracts and wheels for it.
I will be using an OS 55cc gas engine in the front, and nothing in the back. The OS 55 drops right in with the correct spacing from the firewall to the spinner backplate. After it flies, I will consider options for the rear.
The fuselage is very nice and the paint is great. The wings and empennage are covered with some clear iron-on that the paint does not stick to as well as it does to the fuselage. Again, after it flies well, I will strip the covering from the wings and empennage, balsa sheet all openings, glass them and paint them. Model master paints match the existing colors well.
I have been taking photos of my progress so far. I will do each subject as a separate post - with photos and comments.
#105
My Feedback: (19)
MN
Servo Hatches, control horns, and hinges:
For some reason, the servo hatches on the stabs and fins were about 1/4" too small in each dimension for a standard size servo. The ones in the wing for the flaps and ailerons were slightly bigger and were fine. I have no idea why they did this, as it couldn't be to save time or money. It would be just as easy for them to make them so a full size servo would fit easily. I spent several hours making my full size servos fit. The depth was no problem, except for the bottom fin, where I had to "hog" out the opposite side a little bit. Also, so that I wouldn't have to move the slot for the servo arm, I used Air Wild's MLP arms - they position the arm lower down on the servo. I didn't use the servo mount blocks that came with it I replaced them with hardwood - I don't like whatever came with it (too soft) - I think it is bamboo.
I also found that there were no hard points for mounting the control horns. Any horn you used, including the ones that came with it, would have quickly come loose in the balsa. I used Du-Bro's large horns that I like. I glued 4 short pieces of hardwood dowel into each surface (rudder/elevator/aileron/flap) below where the screws for the horn would be. Each piece of dowel went from the surface to almost (but not quite) the other side. Then I drilled a hole down the middle of the dowels and installed the horn with 4, #4x5/8" screws. This worked quite nicely. There were 32 of them to do, so it took a while !!
I didn't use CA hinges as they show. I used my favorites: Hayes (P/N 105). I've been using them for 35 years - since back when Kraft and Hayes were together. Best hinges out there. Be sure to sand them and pre-bend them before installation. I wish they made these bigger for really big models. I have several 50cc aerobatic planes using these hinges with hundreds of flights. However they aren't big enough for airplanes bigger than 50cc.
Brian
Brian
#106
Hey Guys,
I made a little video of my motor setup. I know most will be going with gas like Mr DJ, but the electric is pretty cool as well. I put the front motor into the throttle channel and the back motor into channel 4. In my JR9093 I mixed the two with the throttle as master.
What do you guys think about reversing the rear motor and running a regular prop? Is there a Torque problem having the two motors spin the same way?
Enjoy the clip...it's not fancy.
http://www.youtube.com/watch?v=HtNRA0tfyk4
jim
jim
#108
My Feedback: (19)
MN
Making stabs and fins removable:
I wanted the stab/elevator and fin/rudder assemblies to be removable. Now, if I ever move, it might fit back into the box it came in !!
To do this, I got some 1/2" ID Phenolic socket from Graph tech. The aluminum tubes will be a little sloppy in the socket. To make the aluminum tubes fit tight in these sockets just wrap a few layers of packing tape around the tube - just keep adding a layer until it fits tight in the socket.
Hopefully, the photos explain it all. Please ask if you want more details on how I did anything.
#111
My Feedback: (102)
I am working on the instrument panel right now.. Sorry mine will not be as detailed as that one . Can't pull that out of plastic. Trying to make it one piece.. Anyway.....
Jim, good Video. You may want to check. I had planned on putting the rear motor Batteries in the fuel tank position and then the speed control and then just lengthen the motor wires. Yes that will be a little over 12" to the motor but I don't believe that hurts anything. Its the distance between the battery and speed control that is critical .. I have run this setup in an Me 109 with no cooling over the speed control without any problems or overheating... Just a thought..
Ty
Ty
#112
Agree Ty. I'm just guessing where everything will be...finding the perfect CG, cooling for the ESC, cooling for the Batts, and keeping the wire length acceptable make this setup a challenge for sure. Right now I'm roughing in the plumbing.
Jim
Jim
#114
MD
Jim,
Excellent video... U look just like I pictured U
Man, those electric motors are lookin' and sounding pretty nice. And the non-mufflers are a major plus. I'm almost tempted
Mr DJ
Mr DJ
#115
My Feedback: (19)
MN
Jim:
I saw your video. The lack of a head and mufflers sticking out really makes me want to switch to electric also.
What are you using for:
Front motor
Front prop
Front speed control
Front batteries
Rear motor
Rear prop
Rear speed control
Rear batteries
Will the front motor fly the airplane with the back motor out/off ?
Please explain in more detail what that capacitor is for in the rear.
Brian
Front motor
Front prop
Front speed control
Front batteries
Rear motor
Rear prop
Rear speed control
Rear batteries
Brian
#116
My Feedback: (102)
I have this same setup in a 18lbs Me 109. It has plenty of power. It turns a 21x10 APC prop at about 6000 rpm. I am getting 6-8 minute flights with good throttle management. On the Do335 2 of these would be way over powered. You would be able to cruise at about 1/2 throttle. Wide open should be greater than 1 to 1 on power. I fly the 109 on older 20C batteries. With the newer 35-40c batteries there would be even more power. Batteries have really come down on cost. You can find 160's online for about $125 now and then .. I bought my last 2 for $100 each.. You need at least a Castle Creation 85HV speed control for each motor. I may be wrong and sure will be corrected if I am. I Don't really think you need the capasitor in the rear if you put the Speed control within 12" of the speed control and just make the Motor wires a little longer. In the rear with the batteries installed speed control in place your wires from the speed control to the motor would only be 16-17" long. I don't think that would be an issue. you would rarely need full power with this bird...
Ty
Ty
#117
MD
Ty,
With the Sierra gear and 5" wheels installed, what is the largest prop that can be used? 21", 24", what?
You know I'm a gas man, but those electrics with no disturbed cowl is lookin' somewhat nice.
Mr DJ
Mr DJ
#118
ORIGINAL: bcrc
Jim:
Front motor eflite 160
Front prop not sure...motor will swing a 20-10
Front speed control Castle HV 85
Front batteries 2 Hyperion 5000mah 25c 5s
Rear motor all same as above
Rear prop
Rear speed control
Rear batteries
Will the front motor fly the airplane with the back motor out/off ? I'm guessing slowly...for a short period of time [X(]
Please explain in more detail what that capacitor is for in the rear. As you extend controller to batt wires you need to add capacitors to prevent spikes and ruining the ESC. For an extra 12 inches of wire Castle wanted me to add 5000microfarads of capacitor. Honesty, this one is a stumper. Found much conflicting, murky, debateable info. Start here http://www.rcgroups.com/forums/showp...25&postcount=1
Brian
Jim:
Rear prop
Rear speed control
Rear batteries
Brian
#119
My Feedback: (134)
CA
Jim. Great video.
The question about the capacitors and why we use them. On my 262 project I learned the hard way that without them you can blow the capacitors on the ESC when you connect the batteries on long leads. In my case I had over 24 inches in leads. I blew up 2 castLE HV110 making that mistake. In sum the capacitor acts like a sponge to absorb the energy wave that travel down the lead. The longer the lead the bigger the wave. During my testing I only had a 5 amp drop in power when using them vs no capacitor. They are a must in this type of application.
#120
My Feedback: (102)
There is a guy flying a ASM B-17 with his setup with all the batteries and speed controls in the center section of the fuse and long wires out to the motors and he is having no problems. His wires are way over 17" to the motors. It the length from the batteries to the speed control that is the real big issue. They say there can be some power loss with long leads to the motor. but with what we are looking at here i don't think there is a big problem...
Ty
Ty
#121
ORIGINAL: [email protected]
Jim. Great video.
Jim. Great video.
Does anyone sell large Cap (5000 microfarad) for RC use? I found one on line for a computer that was 5 inches long.[&o]
#122
There is a guy flying a ASM B-17 with his setup with all the batteries and speed controls in the center section of the fuse and long wires out to the motors and he is having no problems. His wires are way over 17'' to the motors. It the length from the batteries to the speed control that is the real big issue. They say there can be some power loss with long leads to the motor. but with what we are looking at here i don't think there is a big problem...
Ty
Ty
Sigh...
jim
#125
You can get E-flite 160 size motors for quite a bit less expensive AND they work just as good.
Hobbyking has the Turnigy easy match G160 for about $50
http://www.hobbyking.com/hobbyking/s...dProduct=14408
and Hobbypartz has the Exceed r/c MonsterPower 160 for $49.70
http://www.hobbypartz.com/mo1602brmo.html
Ive got some monster power motors and they run well. Same with the newer turnigy motors.
