Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
new design: Strega 45
Extreme Speed Prop Planes Discuss the need for speed with fast prop planes (Screamin Demon, Diamond Dust, Shrikes or any REAL sound breakin'''' plane)
Old 03-17-2008, 03:39 AM
look
Default new design: Strega 45
Hi,
This is my new design the Strega 45.
Designed for 40 to 45 rear engines.
The plugs are ready, painted and polished.
Today I am working on the second part of the cowl.
This week I can start with the fuse mold.
Some pictures:
ID:	905581   Click image for larger version
ID:	905582   Click image for larger version
ID:	905583   Click image for larger version
Old 03-17-2008, 03:49 AM
look
Default RE: new design: Strega 45
Fuse length: 101 cm
With spinner: 107cm.
Wingspan: 127cm
Spinner: 2,25 inch Tru Turn
Engine: all FAI or DF or sport engines rear.
Fuse: glass
Wing: foam sheeted with thin plywood.
Wing is CNC cut for servo's, wingspar and retracts.
Ailerons: live hinges of kevlar.
Stab: sym. airfoil foam and thin plywood.
ID:	905587   Click image for larger version
ID:	905588   Click image for larger version
Old 03-17-2008, 03:53 AM
look
Drawing:
Old 03-17-2008, 04:29 AM
Gregor32
Gregor32's Avatar
look'in good! what %airfoil are you using? will you be selling kits? greg
Old 03-17-2008, 08:17 AM
Fxrs_tim
Beautiful work on one of my favorite planes. As Greg asked, what airfoil, and most importantly - how do I get one?
Old 03-17-2008, 10:50 AM
look
Hi,
You can order at speed models.nl.
First I will build the proto but I know how it flies because I used
the airfoils from an earlier design.
The root is 9% and the wingtip is 8% both semi.
The model will fly on rails, stable and depending on the used engine fast.
With an YS 45 it will be a sportmodel, with a Dub Jett FAI a racer.
You can use a muffled tuned pipe or an open tuned pipe.
An open pipe will give more power.
Best regards,
Look.
bob27s
My Feedback: (19)
bob27s's Avatar
Wonderful project !!!
subscribing to follow along with the fun
Old 03-17-2008, 10:52 AM
look
Hi,
I forgot to thank you.
Live the model is even nicer.
It shines like hell.
In a 4 weeks the model is available for sale.
Regards,
Look.
Old 03-17-2008, 11:28 AM
still4given
still4given's Avatar
What is the wing area? This looks like it would be a great model for our RCPRO warbird racing.
Thanks, Terry
Old 03-17-2008, 01:04 PM
look
Terry,
For a half wing the area is 136014.6 mm2
Root is 320mm, wingtip is 147mm.
Wingspan is 127 cm.
Best regards,
Look.
Old 03-17-2008, 01:37 PM
still4given
Cool, looks like that's 460 in2 so for RCPRO I can use a 45 2C or 91 4C.
Keep us posted. I'd love to build one of these.
Blessings, Terry
Old 03-17-2008, 02:01 PM
rmenke
My Feedback: (13)
I'm with Bob, watching you sneaky guys for self preservation. ENJOY
Old 03-17-2008, 02:37 PM
Nickosfly
Hi all,
Signing in for this beautifull project.
Keep on going the good work.
I fly a lot of models from speedmodels and i can say that i like it every minute i flying them!
Just amazing quality, and superb flying capicity.
Grtz
Old 03-17-2008, 02:49 PM
Fxrs_tim
Look,
Do you have any idea how much shipping will be to the US?
Old 03-18-2008, 02:49 AM
look
Hi,
Thank you.
This morning I am making the second part of the belly pan mold.
I will show some pictures end of the day.
Shipping costs to USA are 33.00 euro.
On this thread I want to show the building of the complete model.
The plug is CNC made. The splitting plate and parts are cnc made.
On the plug I have used a very hard 2K paint which can be polished.
Like Coddington uses for his Hot Rods.
All parts for the kit will be cnc cut. The underside of the wing is drawn in cad
and the complete wing will be cnc cut for the servo, wingspar, aileron and retracts.
I will make pictures of that too and show you. All wood parts are excellent quality plywood.
You will get all the information you need to build the model.
Now the first thick coat of epoxy molding stuff has to dry for an hour.
So I can start cutting the glasscloth and carbon roovings.
Tomorrow I will start with the fuse mold. The splitting plate is ready and painted and the mold insert parts are ready for molding too.
The splitting plate is made with straight sides and corners to attach the standing sides so the thick mold epoxy does not run off.
Best regards.
Look.
Old 03-18-2008, 07:52 AM
look
Some pictures:
ID:	906630   Click image for larger version
ID:	906631   Click image for larger version
ID:	906632   Click image for larger version
ID:	906633   Click image for larger version
ID:	906634   Click image for larger version
ID:	906635   Click image for larger version
ID:	906636   Click image for larger version
Old 03-18-2008, 10:43 AM
z06kal
Wow very cool! Any way to get a preorder list going? I would be putting an E-power system in it and shoot for 200+. Fusalage looks quite roomy for batteries!
Old 03-18-2008, 11:26 AM
look
Hi,
Thanks !
That is a good suggestion starting with a pre order list.
Please contact me. In the fuse there is enough room for batteries.
We have used the same airfoils on a smaller model for a 21 engine
and on batteries flying was great.
Here are the last two pictures of the belly pan mold.
That mold is ready now. After four days I can split them and sand the edges with 80 gritt with a machine.
First I will polish the inside, 5x release agent and the first belly pan can be made.
Here are the two pictures:
ID:	906796   Click image for larger version
Old 03-18-2008, 05:56 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
what retracts will fit?
Old 03-19-2008, 01:50 AM
look
I will use the Spring air I think the 607.
They are 34mm wide and 20mm height.
Behotec makes this size too.
Regards,
Look.
Old 03-19-2008, 03:22 AM
look
First I will start with 5x release agent (wax), the cutting of the side walls with the cnc router.
A last layer of release agent and mounting of the side walls
Mounting the iron hardware for the bolts and pins. These will be glued on the splitting plate with ZAP pink.
Tomorrow morning I can start with the thick first layer of grey mold epoxy and the layers of glasscloth, cotton and chopped strands.
Wenn the glasscloth has dried for several hours a last coat of thick gelcoat on top to keeps the stuff in balance.
After four days the other side can be done after sanding the sides with 80 gritt.
Look.
ID:	907507   Click image for larger version
Old 03-19-2008, 10:04 AM
MJD
MJD's Avatar
ORIGINAL: bob27s
Get ready for the big spring rush on 60LX's!
Old 03-19-2008, 10:32 AM
look
Thank you !
Here the pictures before the party tomorrow. Tomorrow I will make the mold. The other side 4 days later.
All is ready now.
ID:	907655   Click image for larger version
ID:	907656   Click image for larger version
ID:	907657   Click image for larger version
Old 03-19-2008, 04:38 PM
Tom Verstappen
Hi Look,
Amazing and you did it again...this beauty looks FAST.........I feel the need....the need for SPEED....
Cheers,
Tom
Old 03-20-2008, 01:42 AM
look
Thanks, Tom !
I can not wait to build my model to fly.
I will build two models: one with an OS 46 DF with a muffled tuned pipe and an open pipe
and the second one with the fastest OPS pylon/ speed maybe a 10cc with an open pipe.
Best regards,
Look.
