Beware of Phoenix Models planes
My Feedback: (128)
I dont post very much, do mostly reading but in this case after losing over $1200 on a very poorly built arf thought I would share my experience and warn anyone interested in buying a phoenix models plane. Im also calling out Tower Hobbies/ Horizon Hobbies and Phoenix models customer support whom after two weeks of multiple attempts to contact by me and fellow AMA members on my behalf haven't heard a peep from either.
2 weeks ago I lost my Phoenix Models Westland Lysander to premature left wing failure which gave away snapping off in level flight at cruising speeds. It was only my third flight after maiden which had only flown 3 level flights with no aerobatics of any kind during all three flights. Small video clip attached of me taking off is literally the nature in which I flew the plane "very scale" with the exception of one intentional stall to learn the characteristics of the plane. As you can see from the pics put many details into the plane with a final weight of 23.6 pounds dry with DLE 61 for power. Things I added apart from stock was meister scale dummy tank, small ladder made from brass tubing, my own scale pilot with some extra detail to the cockpit, landing lights and one coat of black spray paint adding no primer as to achieve a weight under 24 pounds. Model ended up balancing nose heavy with no weight added to achieve proper CG. I have been building for over 26 years from giant scale arfs to scratch builds from plans and never seen anything so poorly made nor have ever had a wing fail never the less on a plane that had only 3 scale flights. It was my first time building a phoenix models plane and it is my last especially since I've had no response from their customer service in the two weeks of attempting to contact them via 11 emails to both their overseas contacts and their state side contacts. Also contacted Tower Hobbies 8 times with several pictures explaining what happened and have yet had any return emails from either of them with the exception of auto response emails. Informed both that I had a half dozen AMA members who witnessed all of my flights and the wing failure willing to contact them on my behalf which some have contacted tower hobbies and again no response, will update my post if they do. Also I attempted to leave a 1 star review on Tower Hobbies website several times under the Phoenix Models Lysander yesterday and it wouldn't allow me to do so, been a member of TH for 17 years and never had that problem before, things that make you go Hmmm.
Pictures are of plane before and after with the wing that snapped showing it is the only thing that is intact because it came off in flight floating to the ground with rest of the plane nose diving in from about 75 feet, only thing survived was the tail section. Also a picture of whats left of the right wing section with cover stripped off. Posted this to show what the build construction of the section that ripped apart on the left side looked like before it failed. You can see how thin the ribbing at the front of wing attached to a single center spar and there is not a whole lot beyond that to sustain a plane this size with a wing loading of 36 oz per square foot as stated in the manual. If the rest of Phoenix Models construction are made the same as the Lysander which they probably are they are very poorly built for giant scale planes and in my opinion a waste of money.
My Feedback: (128)
No doubt the cause was poor construction, have discovered its a problem inherent to this models as 2 other people besides me have lost their wings in the same manner, see link https://www.flyingrc.net/lysandermaid2.html
Far more troubling than the product failure (stuff happens, unfortunately), is the complete lack of customer service. Them ignoring your emails says volumes about their integrity (or lack thereof).
Tower is sure proud of it new website, which has a complete lack of any technical specifications on any product (that I have seen). Oh, and I think we all know who owns Tower (and Omni).
Things in this industry were great 20-30 years ago. They are pretty horrible now.
intresting posts. anybody had trouble with the Waco they make? considering one for a Moki. A pilot at our field has one and the construction of it is "light" but seems sound. The owner puts it through acrobatic manuvers fast and hard. Maybe the bipes perform better with greater wing surfaces? The Lystander design looks weak inherently.
My Feedback: (128)
Then you probably have a model before they changed it to a weaker design maybe or they just made the Waco a better design to begin with. Obviously there is a significant difference between the wing load on a biplane vs the high monowing on the Lysander which they just didn't make the effort to insure it was a strong enough design. So far from my discoveries of the three known Lysanders that the wing failed are all models from 2019 so maybe its something to do with that year as well who knows.
Just saw this...
They wrote,
This is, was a Phoenix Waco biplane. this is a first for me in 50 yrs of flying. the plane disentagrated at 1/2 throttle, straight level flight. the lower wings, outside of the tube spars. the panels on both sides twisted, then blew apart.once that happened the upper wing came off , the struts still connected the fusaloge, went with the upper wing. never have I had a plane come apart like this. upon further inspection, one can see the glue was not bonded to most surfaces. look close, you'll see glue lines, yet no wood fibers in the glue.some areas were glued well, others , the parts were not attached at all. this was the first flight, took off, trimmed it out. stayed at 1/2 power, made a straight pass, all was good, did I one roll, rates were too slow. turned back, straight pass to set up for a landing. still at 1/2 power, the lower wing, both ends twisted, broke apart, top wing went off. the body pancakes in the tall grass. when the top wing blew off , you could see the N struts with parts of the body still attached. all the screws were in place and tight even after the crash.whoever built this one, the glue was dry before they attached the parts. I did notice that the bulkhead needed relying while I installed the radio. everywhere I replied stayed together. never thought the wings were inadiquitly glued. what a mess. I'll have a difficult time trusting planes from this company.
Bob
They wrote,
Bob
Making me want to pull the covering off of my Phoenix ARF. I've got a 40-size SBD sittin' here to build and I'm wondering if it's got the same sorts of flaws the giant birds have. Still haven't done more than loosely assemble the major bits and do a couple engine tests though...the FS70 I put on it just would not run right when mounted to the airplane, but ran like a swiss watch on the test stand and the 4*64 it ended up on.
I purchased the Phoenix 1/3 scale SBACH $1500 after engine and stuff. It went down on its maiden flight when one the horizontal stabilizers walked itself off the mounting tube. There was no locking mechanism, only screw friction. All I was offered from Phoenix was $100 off a new kit. They said no-one else was complaining so they weren't going to fix the design.
Bob
Good to see their customer service is still doing a good job of standing behind their product. Maybe you can edit your review on Tower Hobbies now to reflect that.
I had a similar failure with a hangar 9 model sent it back to them they did nothing.
I think they offered me a 10% discount on another one lol
They basically determined the failure was not a warranty issue on either the radio or the plane as they could not determine the cause of the failure.
They returned the radio and receiver to me and covered the shipping and offered the discount on a new cub.
i moved on to Frsky. Couldn't trust the DX9.
Gave it to a club member who is a very enthusiastic horizon hobby cheerleader.
I think he sold it lol.
