Engine size
[Quote = Jase007; 12.540.720]
hi!
26cc for 1080mm is it's a lot of power. considers that the offshore for the races are 140cm and speed at 110km / h with modified 27cc engines. a zenoah zenoah 26cc would also be fine for your hull, you spend less than 150 euros, you have a reliable engine and the right power.
ciao ragazzi, sto costruendo una Maxcat che è lunga 1080mm un motore a gas 26cc sarebbe ok per questa barca di dimensioni.
Grazie
[/CITAZIONE]Grazie
hi!
