Welcome to Club SAITO !
Old 02-28-2017, 10:33 AM
  #33251
RH
Originally Posted by Hobbsy
A bullet proof product that in most cases will get you about 200 to 250 rpm over the stock exhaust and with the right angle adapter is very easy to hide in a cowl.
http://www.rcspecialties.net/products.php?model=TH12X1A.
Problem solved. I took your (and others) advice and had a look at RC Specialties. I liked what I saw and called The Model Shop in Kentucky, one of the TurboHeader dealers listed. The result: a 12X1A and and adaptor should be in the mail just about now.
I talked with JR Meridith who is one of the owners. Super nice guy, and more than happy to help on this and some other questions that came up. He's been a user and advocate of the old four stroke glow engines for years and is sad to see the decline in popularity of those engines. Nevertheless he is committed to continue to support this aspect of the hobby and plans to remain a provider of the things we need to make the Saitos perform. If it's appropriate I'd like to share his number: 270-781-1476. It may be useful to someone else who runs into this problem.
I should add that as I was typing this I received a call from Jim Coppit, the owner of RC Specialties. I had called them earlier this morning but didn't leave a message. He saw my number as a missed call and called me to see if there was anything he could do for me. Can't ask for better service than that. I guess you could say I'm sold on that company and I haven't even used their product yet.
Rick...
Old 02-28-2017, 10:39 AM
  #33252
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Yep, Jim is a great guy and a good friend.
Old 02-28-2017, 10:46 AM
  #33253
RH
To all the commenters on my FA 40...
Good tips. In fact I've used a couple on some other old carbs in the past. This situation seems to be different though. The engine is brand new and hasn't been run so I don't think that the carb has been fouled with old fuel. The barrel is half open so when looking down the air intake I can see what looks like rust along the seam between the barrel and body. I've used a magnifying glass to get a closer look. I've also taken a pick to it and there is definitely a solid rough build up in that area. Since the carb is not listed as a stocked item at Horizon they suggested that I send it in for them to have a look at it even though it is not warrantied to me as the second owner. He hinted that they might have an old one laying around in their 'parts bin'. I'll give that a shot unless I can come up with another source.
Rick...
Old 02-28-2017, 10:52 AM
  #33254
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Just for kicks, here is an early FA .40 and an FA .40a side by side.
Name:	Saito .40s 002 (Small).jpg
Old 02-28-2017, 12:11 PM
  #33255
spaceworm
I did not realize the big difference in size. What accounts for that? I see the new case design on the new one, but that couldn't be the reason for the reduction in size? Even the jug is smaller (I like big jugs)
SAITO FA-120abc
VBR, Richard
Old 02-28-2017, 03:57 PM
  #33256
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The current FA .40a and the little .30 side by side, not as much difference.
Name:	Saito .40a and .30 001 (Small).jpg
Old 02-28-2017, 04:52 PM
  #33257
RH
Might the carbs be the same? May not matter though because I don't see a .30 glow listed on Horizon any longer.
Old 02-28-2017, 04:53 PM
  #33258
blw
blw's Avatar
I forgot to mention W8YE when I was talking about moderating in Engines. Jim has been here the longest and knows more than anyone else I've known when it comes to engines. I know Dave thinks of Jim as a close friend as I do myself. He looks in here often but has his hands full in gas engines.
Old 02-28-2017, 08:09 PM
  #33259
georgiateddy
georgiateddy's Avatar
Default Saito FG61 TWIN Exhaust Guidance
Wow..........this "Club Saito" is something. Funny that I have 5 Saito engines. Anyway I need some direction. Tomorrow I have a Saito FG 61cc twin arriving. The engine is for a special cub build. I am building a 120 inch 50CC J3 Cub to replicate (as close as possible) the Hanger 9 Carbon Cub 15cc.
The engine comes with two flex pipes. They appear about 6 inches long each. I am sure they would work fine; however, I really do not desire to use them. My wishes are to have a header pipe of about 3 to 4 inches long coming straight down from each side of the engine and perhaps 45 degree towards the rear.
The modification will likely increase decibels; however, this is not a factor where I fly. To the best of my understanding the FG61 is the big brother to the older FG57 Twin.
Any exhaust/header ideas would be appreciated.
Teddy
Old 02-28-2017, 09:20 PM
  #33260
jeffie8696
jeffie8696's Avatar
This is my newest Saito. Its a 1.80 on a SIG 4Star120
Old 03-01-2017, 01:34 AM
  #33261
Rudolph Hart
Rudolph Hart's Avatar
He sure is.Sent me a turboheader for an 82 and one for my 220 they sound different to a cast muffler.Really well made.
Old 03-01-2017, 01:54 AM
  #33262
Rudolph Hart
Teddy
Well pard you just sashayed into the right alley,just kidding. you can cut the flexi pipe at the header flange (as well as big jugs i like them too richard) and get a shotgun pipes tig welded on as in the pic.I spose you looked up 'montana mike' on you tube he flies a big cub with the fg57t,lots of horsepower.He suffered from an early saito ignition module that was fixed by the time i bought mine.Unforgettable sound after priming and then flicking it to life.When it fired first time i jumped back further than the dog did.Benchmark prop was an apc 22x10 at 6500,i'm half a turn rich with a menz 23x10 let us know how you go
Old 03-01-2017, 03:54 AM
  #33263
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
R, the carbs are not the same the .30 has a simple non metered, air bleed carb and the .40a has a two needle carb, both are very good at their respective jobs.
Old 03-01-2017, 06:05 AM
  #33264
RH
Although I have an adapter coming with it, I may be able to mount it directly to the engine. What's the standard practice for mounting the TurboHeader? Either with or without the adapter, do you recommend using any thread locker or anti seize products?
Old 03-01-2017, 06:09 AM
  #33265
BJ64
BJ64's Avatar
.... soooo... from what I've been reading lately... a 50-cal Saito is the way to go these days... (????)... ***?
BJ
Old 03-01-2017, 06:22 AM
  #33266
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
On a Saito 1.50, fancied up a little.
Name:	Saito 1.50 TH and vent.JPG
Old 03-01-2017, 06:36 AM
  #33267
FlyerInOKC
FlyerInOKC's Avatar
Teddy
Teddy, I would contact these guys and tell them what you want to do. They are very helpful.
Old 03-01-2017, 07:06 AM
  #33268
spaceworm
Nice 1.50! I read from your earlier posting the CDI ign. tamed it a bit. A future mod to my 1.80.
Dave, does the tube extension have any effect on the TH tuning? Is there a length limit? Thanks.
Very Best regards, Dick
Old 03-01-2017, 08:31 AM
  #33269
N1EDM
Hobbsy, +1 for what Spaceworm said... Thanks!!
Old 03-01-2017, 09:46 AM
  #33270
spaceworm
BJ
A 50 cal bore with a .50 inch stroke would have a displacement of 0.098 cubic inches!, or 1.609 cc. Close enough to 0.099 ci.. Did Saito ever make an engine that small? Or is it even reasonable to make a 4 stroke that small?
Sincerely, Richard
Club Saito #635; Saito 56, 100, 120abc, 130T, 180
Old 03-01-2017, 11:29 AM
  #33271
FlyerInOKC
FlyerInOKC's Avatar
Sincerely, Richard
Smallest 4 cycle I can remember seeing is a Saito is the FA-30SH which would be about 5 cc.
I owned an O.S. Pet III in .099 2 cycle and I can't see that being built as a 4 cycle.
Old 03-01-2017, 11:36 AM
  #33272
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks Richard, that is possibly the first 1.50 that Horizon sold, at least according to a lady who worked there at the time. The K&S tube is much larger than the outlet in the TH, it does not change the tuning at all. The 1.50 now wears the newer red trigger wheel and sensor. All these years have kept this picture of KMOT'S red Saito .45, to me it's impressive.
ID:	2203543   Click image for larger version
Name:	Saito .45 Red.jpg
Old 03-01-2017, 11:57 AM
  #33273
FlyerInOKC
FlyerInOKC's Avatar
What is the displacement of that red beauty?!
Old 03-01-2017, 12:01 PM
  #33274
spaceworm
I am thinking a Saito .45 would.be .45 ci?
Old 03-01-2017, 12:05 PM
  #33275
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Yep, it's a .45 and he added stainless steel screws.
