Welcome to Club SAITO !
Old 06-03-2018, 05:24 AM
  #36676
Cougar429
Cougar429's Avatar
Throwing the prop is most often due to lean on the HS needle. Found that out the hard way on my first Saito, also the 91.
I have 3 self-contained starters, the one in the pic uses a 4S Lipo too long in the tooth to fly. Turns over everything up to my 125's.
The Super ;Bolt has a 100 mounted with a Tru Turn spinner. That uses the double-lock system, with the secondary nut also the adapter for the bolt holding the spinner to the back plate.
Old 06-03-2018, 06:20 AM
  #36677
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
When it kicks back while starting it's usually because it's too rich. (over primed)
Old 06-03-2018, 06:46 AM
  #36678
acdii
hmm it had just ran, I had an issue with the servo setting and could not get the idle down, so had stopped it, but did that by leaning it out at half throttle. It kicked back after that time as well. It wasn't running smooth at WT and when trying to adjust it, that is when it spit the prop.
Should I need to touch LSN to correct, or just the high speed?
Now here's what makes me SMH. The prop with spinner and all hit the side of my truck, didn't leave a mark, yet road salt kicked up from a car ahead chipped the crap out of the paint! The prop whacked it pretty hard too.
Old 06-03-2018, 07:34 AM
  #36679
Captcrunch44
but according to Gm that aluminum body is no good. Shows you how much they know
Old 06-03-2018, 10:54 AM
  #36680
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
My Dad always said that GM let the public do their R&D for them.
Old 06-03-2018, 03:32 PM
  #36681
Jesse Open
Jesse Open's Avatar
My Grand-dad always said Henry Ford was a little too friendly with Adolph Hitler.
And very hard on the Jewish people. Many people in the Detroit area got to see that first-hand.
And that is real history.
Old 06-03-2018, 06:33 PM
  #36682
the Wasp
Jesse, have you ever run a RCV engine for any length of time so that you can comment on them ? I'm not looking to buy one, I just find them interesting, so I thought I would ask you if you knew much about them ?
thanks
Jim
Old 06-04-2018, 12:57 AM
  #36683
Rudolph Hart
Rudolph Hart's Avatar
Thats a nice looking superbolt cougar,a club mate flew one with a fa91 fitted,it was beautiful to watch.
Bruce re priming your 91 dave is right it's too rich and will kick back violently as you say.I've had a few start and run backwards because of that so it's a scramble to get the throttle trim down so it stops if the engine is fully cowled.Or you can block the exhaust with your finger.Ideally you flick the prop with a finger over the carb inlet three or four times and then flick the prop with your finger off once or twice,you should hear that half wet sound they make if it is quiet and no one is running up an engine.If it's noisey/engines/wind etc hook the glo plug up before you do the priming and this time just turn the engine over slowly by hand while priming.You will feel a bump back from the prop when there is enough fuel in there for the 91 to start,avoids flooding the engine when done carefully.As far as tuning goes for max rpm without being lean at wot you will find it difficult if you do not wind the lsn out rich at idle and start on the hsn first.
Dave you are right i googled rolls royces new colours,there is the odd green one in there,living proof that serious money does not give you everything.As for the 20" lift kit and go anywhere button i reckon anybody with that amount to spend can do exactly that i wish i had the pictures to prove that i've gone fox shooting out in the wheat belt here at night and a spotlight in a rolls royce with the roof cut off.It was a typical wheatbelt paddock with a few rocks here and there but you shoot better off the back of a roller because it's not as bumpy as a fourwheel drive.
Old 06-04-2018, 02:19 AM
  #36684
Jesse Open
Jesse Open's Avatar
Default Over Primed
Latest starter, gear reduction and self contained, home brew from commercial scooter starter uses 3S / 5200 mah hard case LiPo Easily starts 80cc .
Those over primed engines that like to start backwards will ousally start and run correctly when flipped backwards. Not hard, just enough to bounce back. A bit of a technique but works well. Some Saito instructors actually describe it as the preferred method IIRC
Last edited by Jesse Open; 06-04-2018 at 02:58 AM. Reason: Correcting spell check's error
Old 06-04-2018, 02:53 AM
  #36685
Jesse Open
Jesse Open's Avatar
thanks
Jim
Sorry but no, I haven't. A fellow club member has one and I am still waiting to see it run. Almost bought one when they were shown at Toledo a few years ago. They do show up in the classifieds at reasonable prices at times. May have to pick one up.
Old 06-04-2018, 03:03 AM
  #36686
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The .58 CD is over an inch shorter in height than an OS .52.
Jim, a few years ago I had a .90 SP and a .58 CD, the .58 was a sweetheart, the .90, well, I just couldn't find a practical use for it. The .58 turned a 13 x 6 at 9,000 rpm, on 10% fuel with 16% lube exactly as RCV claimed. I forget what the .90 SP turned, a 16 x 12 four blade I think @ 5,500.
Old 06-04-2018, 03:15 AM
  #36687
Jesse Open
Jesse Open's Avatar
Just for the sake of diversity, a couple more conversions to self contained starters. One is a handy little gear reduction Kavan starter. Starts the OS Gemini 160 very nicely but limited to 80 size singles. Again a #S LiPo pack for power.
The other is the good old Sullivan Hi-Torque. This onewas done years ago pre LiPo; Now has a pair of 3S LiPo in the box. Also fitted with a easy to actuate lever switch that in turn drives a high current relay. Very low voltage drop.
The self contained starters have a good power edge over the corded versions.
Old 06-04-2018, 03:25 AM
  #36688
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
The RCV .58 CD is over an inch shorter in height than an OS .52.
Old 06-04-2018, 04:11 AM
  #36689
Jesse Open
Jesse Open's Avatar
The Brits really like those spool valve engines. I bought one of these back in 1982 and had it on a 2 meter Fokker D VII.
It ran OK but the carb was problematic. Wound up with a good old Super Tigre MAG type carb.
A bit square looking .Reminds me of Laser engines a bit.
Old 06-04-2018, 04:17 AM
  #36690
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
It's like this around here today and yesterday.
Old 06-04-2018, 04:23 AM
  #36691
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
https://www.horizonhobby.com/182-twi...A-dd-saie182td
Currently in stock:
Old 06-04-2018, 05:13 AM
  #36692
Jesse Open
Jesse Open's Avatar
Originally Posted by Hobbsy
Just ordered one. This starter will start it with ease:
Old 06-04-2018, 06:16 AM
  #36693
acdii
Whats the thread size on the 91, I think I will just do what I do with my other planes and use a small spin on cone that also acts as a locknut.
Old 06-04-2018, 06:25 AM
  #36694
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Here's the skinny:Bore:1.11 in (28.20 mm)Carb Type:barrel 2 Needle ValveCrank Type:Ball BearingCrankshaft Threads:M7 x 1mmCylinder Type:AACCylinders:SingleDisplacement:.91 cu. in. (14.91 cc)Engine (Only) Weight:18.34 oz/520g,18.34 oz/520gMuffler Type:CastMuffler Weight:2.12 oz/60gRecommended Fuel:GlowStroke:0.94 in (24.00 mm)Total Weight:20.46 oz/580g
  #36695
Jesse Open
Jesse Open's Avatar
7 x 1.0
Good luck
Old 06-04-2018, 06:26 AM
  #36696
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
https://www.horizonhobby.com/product...-ee-saie091sgk
You might want to copy this while it still exists.
Old 06-04-2018, 06:30 AM
  #36697
acdii
Thanks, I may already have one! The shank is too short for a large spinner and can only fit one nut on with the washer, and just don't have time to go shopping for a thin back plate spinner, but know I can get the cone nut from the LHS for now. Have the SIG fly in this coming weekend, and it needs to be flown or a certain crunch type fellow will be a little peaved.
Old 06-04-2018, 06:37 AM
  #36698
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Product Listing -
A sure cure
Old 06-04-2018, 06:42 AM
  #36699
Jesse Open
Jesse Open's Avatar
I make up a piloted primary nut that fits into a counter-bored prop. Allows for a jam nut with plenty of room for the spinner and threads to spare. Similar to the True Turn.
You can also find thread info and store bought True Turn info here:
http://saito-engines.info/prop_nuts.html
Old 06-04-2018, 07:11 AM
  #36700
acdii
So you ream the prop for the nut then?
