Welcome to Club SAITO !
#4201
RE: Welcome to Club SAITO !
Hi Bill Robison,
Remember back in 7/14 I wrote asking about clicking noises from my .30 when rotated by hand? You were the only one responded.
The clicking came from momentary cam reversals just past lobe peaks, abruptly stopping after taking up excessive backlash in the cam drive gears. It probably is of no consequence when engine is at running speeds. Momentum of the cam shaft should prevent reversals then. The clicking just bothered me. I had to fix it.
Now the problem had been fixed to my satisfaction. I have to put my ear right up to the engine to even hear the very subdued clicks. It took two tries to tighten up the gear mesh sufficiently. A total of .006 inch was removed from the cam box by lapping. I also replaced the rear bearing that was a little rough.
It now feels like a precision piece of machinery, smooth and without the "clackety-clack".
Philip
Philip
#4203
My Feedback: (24)
ORIGINAL: [email protected]
Philip
Philip
#4204
MB, CANADA
Hob
One other thing I noticed on my test stand; my throttle adjustment wire was pushing the thottle barrel inward, overcoming the internal spring. This was causing the HS to go lean. I wonder if this is causing those lean runs we keep reading about. Just one more thing to be aware of. I now wonder if my plane installation was doing the same thing?
#4206
My Feedback: (102)
Here are my two not so indentical twin Saito .30s, the new one came with a prop nut and an eccentric jam nut ala YS. The old one came with the prop nut you see in the picture. The old one also has WRs extra cooling capacity coating on the outside of the cylinder and his, "good for 5 HP" coating on the inside called "Robislick".[8D]
#4211
CA
I saw this somewhere before but I can't seem to find it again. What is the ID and OD of the o-ring?
ORIGINAL: w8ye
Unbolt the carb... slide the velocity stack over the carb aligning the holes... and re-install.
Most people put a O-ring in between the velocity stack and the carb.
#4213
FL
ORIGINAL: Hobbsy
Correction, that spinner nut came with a ModelTech Cub on which I had the old .30 mounted inverted.
JettPilot
#4215
My Feedback: (16)
I have 3 silver Saito 30's. One I bought used and it had the Saito spinner nut on it like in Hobbsy's picture.
The other two I recently bought new at Hodges Hobbies in Andersonville, GA and they have just a plain hex nut on them. The engines were fress from Horizon.
Never had any trouble with either
#4216
My Feedback: (102)
JP, I loaned Bill R. my Saito .30 a few months ago to get himslef prepared for a Saito maintainance Seminar. While he had it he colored the cylinder black, the inside coating thing was just a little fun thrown his way. He ain't got no sense of humor so I'll have to call him and splain it to him.
#4217
My Feedback: (102)
MM, the .40a arrived today, great packing job, best in fact. When I saw where the vent fitting is I remembered that the 2.20 has a boss cast into the same spot but no vent. Thanks MM
#4219
CA
New topic, Props.
What is a good range of props for a Saito 65, vintage 1980, but with very low time, maybe 2 hours.
Plus what RPM should I be trying for?
#4222
I installed stacks on my .91 and .82 , both engines exhibited less power and obvious lower max rpms even after tweeking them a bit on the test stand. I wonder if the o ring ( from a saito kit ) was causing the problem even though it looked to me like a good fit? Otherwise, I dont know why the difference in performance. After removing the stacks the engines ran a little smoother like originally.
Bill #108
Bill #108
#4223
My Feedback: (102)
The placing of this vent on the cam housing raises my couriosity. I'm used to seeing about a teaspoon full of oil in the crankcase of the smaller Saitos and about a tablespoon full in the larger ones. I'm going to run the .40a today for about an hour and then pull the backplate to see the oil content. I'll use a Graupner 10.5x6. If I have an 11x5 I'll use it.
