Welcome to Club SAITO !
#6551
My Feedback: (102)
RE: Welcome to Club SAITO !
I did, the baffle has virtually no effect on the rpm but the sound is much nicer with the baffle. I'm hoping one of the HP calculatin gurus will see which has the most hp the 14x6 @ 10,050 or the Bolly 13.5x8 at 9,850. I didn't expect that kind of rpm with the Bolly.
#6558
My first post to the club! I took up flying Powered Parachutes about 6 years ago and lost interest in R/C. I am jumping back into r/c feet first and now need some help from club Saito.
Issue #1
What I have: U-Can-Do .46 with a borrowed Saito .72 engine. (minus landing gear since a deadstick last Saturday, Doh!) 30% Morgan Heli fuel, new O.S. F plug, mounted inverted.
What it does: It randomly dies in-flight. Flying straight and level, sometimes sputters when I pull up hard, 2-3 normal flights, the next one it dies. It seems if it dies once, it will usually die again in the next flight or two. It is very unpredictable.
What I have tried: I used Hobsy's tuning method, peaked the HS with a tach, then peaked the LS with a tach, then richened the LS about 300 RPM, then peaked the HS and richened about 400 RPM. It gives a nice smoke trail when flying and idles good to slightly rich.
Suggestions from others I haven't tried: Install a fuel filter, re-isolate the engine mounting to make sure there are no bubbles, setting the valves, get an O.S. :P
Is there anything else I am overlooking here?
Issue #2
I'm installing a Saito 1.80 inverted in a CMPro Giles 202. The carb hits the motor mount and will not let the engine go far enough back. It looks like the simplest option is to rotate the intake 90 degrees. I will be using an Ironbay regulator, so the carb position shouldn't be a factor, but I am concerned about the vibration and the intake/carb staying in place.
Thanks!
Kendall
Baton Rouge, La
Issue #1
Issue #2
Thanks!
Kendall
Baton Rouge, La
#6559
#6560
CA
If Hobbsy's suggestion to richen the low speed doesn't work, I would tell you to backflush your filter if you have one and check your tank positioning. Something is causing the engine to lean out.
Do you have the pressure line from the muffler to the tank connected properly?
I have never had a problem from rotating a carb on a Saito, nor have I ever heard of one. It should be perfectly fine the way you described.
The Iron Bay regulator is a very nice unit. I would recommend, based on personal experience, that you pull the nipples off, clean the threads in both the housing and on the nipples, get some O-Rings that will fit properly, liberally apply blue LocTite to the threads and tighten down. Clean up the excess LocTite and let it dry for an hour. The reason I suggest this is because I had a massive air leak in my IB regulator and I believe it may have caused me to damage an engine (not sure if the engine is damaged yet, most likely there is just a lot of crud in it from using Marvel Mystery Oil as an ARO *sigh*, but it is possible that the air leak caused it to run very lean and hot - Hobbsy is checking it out for me).
#6561
TX
Hello, I want to use the motor mount that Saito provides for their FA-220 engine. (p/n SAI220A95) Does anyone know the distance from the firewall to prop hub face for this mount. I need to see if the mount will provide adequate spinner to cowl clearance for the plane I plan to put it on and since the mount has the motor holes already drilled and tapped, the distance is fixed.
TIA.
RFan
#200
TIA.
RFan
#200
#6562
My Feedback: (12)
MT
ORIGINAL: PPCFlyer
Issue #1
Issue #2
Thanks!
Kendall
Baton Rouge, La
Issue #1
Issue #2
Thanks!
Kendall
Baton Rouge, La
One other thing, don't fly without a filter. These things aren't cheap but a filter is cheap insurance.. Hope this helps
Shane
#6563
My Feedback: (12)
MT
Got a question concerning running the crank nipple into the ful line, do you think there will be any adverse effects from the pressure in the crank? Should i run a check valve between the "T" and the tank? Here's a pic of what it looks like.
Shane
Shane
#6564
I doubt that your system would work too well - if at all. If the tank is pressurised from the muffler it will try to force fuel into the crankcase, and even if that doesn't happen, the varying pressure in the crankcase will cause an erratic fuel supply.
Much better is to do what OS engines have been doing for some time now. Fit a nipple onto the inlet pipe close to the carb and connect the breather to it. I silver solder the nipple in place, making sure that it does not protrude into the inlet pipe to impede the gas flow. I have two Saito 82s which I have done this to with no apparent problems - and the one has had many, many flights on it. It certainly saves a great deal of mess on the airplane. Both my engines are in cowled planes where I can't add ARO so at the end of each flying session I close the throttle (to ensure maximum suction from the crankcase) and spin the engine for a few seconds to remove as much residue from the crankcase as possible.
I also "converted" my older OS engines the same way and have had no problems with them either. It seems to me what is good enough for OS must also be OK for Saito. Try it. You will be amazed at how much cleaner your airplane stays.
If anyone can think of a reason why this might be harmful, I'd be interested in their comments.
#6565
My Feedback: (12)
MT
Thanks Lynton, thats what I was worried about. What size drill do you use for the inlet and do you tap it or just solder it in place. I saw the new RCV 130 is tapped that exact way into the intake tube, I will give it a try.
Shane
Shane
#6566
WI
W8YE started a thread in glow engines notifying everyone that Hobbsy is in the hospital.
Here is the thread: http://www.rcuniverse.com/forum/m_5525615/tm.htm
#6567
Hi Shane
The wall of the inlet tube is so thin that you can't tap it. Just drill a hole to the size of the nipple and gently file (or grind) the chrome plating off around the hole to give the solder a good bond to the brass underneath. I used silver solder because I have the necessary tools, but I'm sure soft solder would do just as well.
Good luck.
Lynton
Good luck.
Lynton
#6570
I recently purchased a used saito .56 that the previous owner thought that the retainer clip came off of one of the valves. When I opened it up, I found that one of the rocker arms was broken. The exhaust valve had stuck and caused the arm to break. I removed the valve, cleaned the guide by using multi purpose lube and running the valve stem in and out from the top side. in a short time it moved very freely. I put it back together and it now has compression but feels weak. Should a ringed 4 stroke feel high compression like a regular 2 stroke?
#6573
My Feedback: (8)
About the plumbing of the crank case vent into the intake pipe...
The only detriment might be a slight loss of power because of the change in vacuum through the induction tract, and dilution of the fresh air/fuel charge.
IMO, it's best to just dump it overboard by running the case vent line down along side the exhaust parallel with the muffler, and letting the schmutz (sp?) mix with the exhaust.
I wouldn't T the case vent into the tank plumbing, or exh. pressure line.
#6574
Just posted this same question in the general questions section cause I somehow missed this topic all together.
Anyway, I have taken my Saito 150 apart to replace the bearings, but there doesn't appear to be a timing mark on the crankshaft! The cam gear has one. What can I do?
John
John
