Welcome to Club SAITO !
Old 07-31-2007, 11:20 AM
  #8001
jdr43
jdr43's Avatar
Default RE: Welcome to Club SAITO !
Tbone, I'm using an on board glow driver by Ram on my Saito 62A mounted on a Slow Poke 40, Idles around 1800. Anything past 1/4 idle and the on board glow cuts off.
Jim R
#510
Old 07-31-2007, 01:41 PM
  #8002
Kmot
My Feedback: (24)
Kmot's Avatar
Not a glow fuel engine, it's gasoline. None the less, I thought the Saito enthusiasts would appreciate it:
http://www.saito-mfg.com/single-files/fg-36/fg36.html
Old 07-31-2007, 02:05 PM
  #8003
Ernie Misner
Ernie Misner's Avatar
Confused, the saito carb's needles will sometimes affect each other........ so try opening the high speed needle about 2 turns or more, and then reset the low speed and see what happens.
Ernie
Old 07-31-2007, 05:57 PM
  #8004
bldrums
bldrums's Avatar
Ok , I know its here somewhere....I have never had great luck when using search here probably because we have so much info. ( rant rant rant ..sorry )
FA 1.25 with original Saito glow plug. Couldnt run better!! So , now that its about 25 or 30 flights old or so, I would usually go to a OS F 8 replacement plug but Im afraid to change ANYTHING!![X(] If if aint broke dont fix it but sooner or later it will need a new plug........anyone switched out the stock Saito plug in their FA 1.25 yet?
thanks yall
Old 07-31-2007, 06:31 PM
  #8005
blw
blw's Avatar
Yes. I always pull out the original plug after the break in and a flight or two, and put a new one in. I'm using Saito SS plugs now.
Old 07-31-2007, 09:17 PM
  #8006
Tbone4life
Tbone4life's Avatar
ORIGINAL: jdr43
Jim R
#510
I want my Saito 100 to idle at or under 1000rpms.
Old 07-31-2007, 09:58 PM
  #8007
jb86
My Feedback: (8)
i use saito plugs in a saito (i ordered a couple hangar 9 plugs, they sent saito brand). os "f" in os and ys. people have told me to use only ys or os in ys engines. the saito/hangar 9 is a good plug for saito's. i have been under the impression there is a difference between the two. in some ways the hangar 9 is better quality.
jon
Old 07-31-2007, 10:05 PM
  #8008
blw
blw's Avatar
An idle at 1000 RPM may be unrealistic for a Saito.
Old 07-31-2007, 10:27 PM
  #8009
RCWI
RCWI's Avatar
Hey Guys: im having a problem with my saito 1.25. its in a H9 spitfire and when im fueling it, fuel is running out of the carb. if i close the carb then it runs out of the crome tube that goes from the carb to the head. I have a vent, and it is clear, meaning i can blow through it easly. If i pinch the tube going to the carb I can fuel er up jus fine. Any ideas???
Old 08-01-2007, 12:15 AM
  #8010
Tbone4life
Tbone4life's Avatar
ORIGINAL: blw
Thats what everyone tells me. I still need to try the 15x6 APC sport on it 1st.
Old 08-01-2007, 12:17 AM
  #8011
Tbone4life
Tbone4life's Avatar
ORIGINAL: RCWI
What tube are you pumping the fuel into? you should use the carb tube. The clunk(carb tube) is at the bottom of the tank and any fuel with pressure added to tank is coming out the clunk tube.
Old 08-01-2007, 02:27 AM
  #8012
Red B.
ORIGINAL: blw
I get around 10,600 on my .72 on 15%. 12,000 RPM is the limit.
I checked the RPM of my Saito 72 yesterday. With an APC 13x6 I got 10,700 rpm using 10% nitro / 15% oil / 75% methanol.
Old 08-01-2007, 08:27 AM
  #8013
Bill Lowen
Bill Lowen's Avatar
I need a manual for a Saito FA 65. Anyone here at Club Saito help me out with a link?
Old 08-01-2007, 09:08 AM
  #8014
GX Ame
GX Ame's Avatar
Hello folks.
Disassembled my FA-72.
I wasn't watching when I removed the piston pin from the piston.
Which end goes forward, the end with the small opening, or the end with the larger opening?
Thanks.
Old 08-01-2007, 09:38 AM
  #8015
blw
blw's Avatar
Bill,
Here is the manual link: http://www.horizonhobby.com/ProdInfo...der_Manual.pdf
Old 08-01-2007, 09:46 AM
  #8016
Bill Lowen
Bill Lowen's Avatar
I got this..
Directory Listing Denied
This Virtual Directory does not allow contents to be listed.
Old 08-01-2007, 09:48 AM
  #8017
Bill Lowen
Bill Lowen's Avatar
wait, maybe not... 2nd time may be a charm..
Old 08-01-2007, 09:59 AM
  #8018
Bill Lowen
Bill Lowen's Avatar
It worked... Horray!!! Thanks BLW!!!! You rock. Hey, since I am the proud owner of a Saito now, can I join the club now??
Old 08-01-2007, 10:06 AM
  #8019
blw
blw's Avatar
Glad you got it. You are member #537
Old 08-01-2007, 10:24 AM
  #8020
Bill Lowen
Bill Lowen's Avatar
awesome!!! This is my first go around with Saitos and four strokes for that matter... The guys at the field rave about these Saitos so if you can't beat em, join em.. I still love my OS 2 strokes though.
Old 08-01-2007, 04:24 PM
  #8021
ScaleKing
ScaleKing's Avatar
I have a question!
I am new to saito engines but from what I have heard then seem to be pretty damn good. That said...I have installed a FA-220a in my H9 P-51D. My trouble is getting it to idle without cutting out and keeping my model from moving. I am runnig a APC 19x8 two blade in it right now. Anyone with advise on this? I want my bird not to move when the engine is idle.
HELP
Old 08-01-2007, 04:31 PM
  #8022
ScaleKing
ScaleKing's Avatar
Next question..is a 16x8 three blade too little of a prop for this engine?
Old 08-01-2007, 05:05 PM
  #8023
Gringo Flyer
My Feedback: (18)
Gringo Flyer's Avatar
ORIGINAL: blw
Hey blw dont forget I just bought my first Saito. I guess I have a reason to read this thread now.
I cant wait to get mine fired up!
Old 08-01-2007, 05:12 PM
  #8024
bldrums
bldrums's Avatar
blw
Ok , right now the plug that I am using is the Saito SS. ( original equipment )
So, you use the "stock" Saito plugs all the time? ( Saito ss ?)
Old 08-01-2007, 07:35 PM
  #8025
jb86
My Feedback: (8)
can't go wrong w/a saito plug in a saito. i said earlier, i ordered hangar 9 plugs a few weeks ago (they are supposed to be basically identical), i was sent saito "ss", they may now be the same plug.
i use os in an os and ys (or ys in ys).
i have been told there are differences in some ways, but the saito plug is very good, stay w/it. and priced below os type "f".
jon
