Welcome to Club SAITO !
Old 01-01-2006, 01:33 PM
  #1201
lrr
lrr's Avatar
Default RE: Welcome to Club SAITO !
Thanks to all for the encouragement, advice, etc.
Gary,
Wow -- Trona -- you get lots of flying days each year! I worked at China Lake in the late 70s, and know exactly where Trona is ...
Lee
ORIGINAL: gjeffers
hi Lee, since i have never owned a kadet i dont know how a inverted saito will mount in comparison to the fuel tank, but if the carb is lower than the tank there will be flooding, the lower the carb in relation to the tank the worse.just something to think about
sounds like a great combo, youll love your saito
good luck!!
Old 01-01-2006, 02:34 PM
  #1202
gjeffers
gjeffers's Avatar
ORIGINAL: lrr
Gary,
Lee
ORIGINAL: gjeffers
good luck!!
yes i do Lee, matter of fact im heading out now to fly[8D]
showing about 58 deg and cloudy but nice and calm
thanks for not making a comment about the smell
Old 01-01-2006, 04:21 PM
  #1203
Nickolas
Nickolas's Avatar
Hi,
What is a recommended tank size to give around 8-10 mins flight with Saito 82? I just installed a 10 oz on my plane. I wanted the smallest availabe option as this is a 3D plane so weight matters a lot.
The problem I face is that the tank center line is at a higher level from the carburetor. Do you think this is a problem?
Looking forward to replies, rgrds.
Nick
Old 01-01-2006, 04:31 PM
  #1204
William Robison
[b]Nick:
Dialed in properly you should have 10 minutes plus reserve from a 10 ounce tank on your FA-82. Depending on throttle use you could have 15 minutes from it.
...tank center line is at a higher level from the carburetor. Do you think this is a problem?
Some people have gotten away with it, all I can say is try it if you can't lower the tank.
Bill.
Old 01-01-2006, 04:37 PM
  #1205
Nickolas
Nickolas's Avatar
Thanks, so I could possibly use an 8 oz right? I used to have an 8 oz when I had an OS-70 Ultimate on the aircraft, I thought that Saito would consume more that's why I went for the 10 oz. Would you recommend to switch back to an 8 oz?
Nick
Old 01-01-2006, 04:46 PM
  #1206
William Robison
Nick:
It varies depending on prop and the weight of the plane, but a Saito generally will burn one ounce per cubic inch per minute at full throttle when adjusted properly.
In other words, at full throttle your engine should burn a hair more than 0.8 ounces per minute at full load. If you don't spend the entire flight at 100% power you should have no problem getting more than ten minutes from your 8 ounce tank.
Bill.
Old 01-01-2006, 04:48 PM
  #1207
Bipe Flyer
Bipe Flyer's Avatar
The larger Saitos seem to be more fuel efficient than the smaller ones. My Saito .30 gets less than 5 mins on a 6oz tank.
Old 01-01-2006, 04:50 PM
  #1208
William Robison
BF:
Try leaning the LS a bit. Your 30 should do better than that.
Bill.
Old 01-01-2006, 05:00 PM
  #1209
Bipe Flyer
Bipe Flyer's Avatar
The LS is an airbleed and I have leaned it a little, but it is still fairly new. I've got about 25oz through it. Here is a video clip of the first flight with a 4oz tank. As you can see, the engine quit at 3:02, but I had run it on the ground to do a range check and set the needle. I swapped in a 6oz and set my timer to 4:30 and when I landed there was very little to pump out.
http://donatelli.net/pittss2s25/Pitts-S2S.wmv
Old 01-01-2006, 09:11 PM
  #1210
solafein
solafein's Avatar
The flight fuel efficiency on all my Saito's aren't up to snuff. If I were more courageous and leaned the LS out a little I would do better, but I have never had to replace bearings in any model engine running them a little sloppy. I have 10 gallons through my .91 and it runs like the day it was installed, 2 years and an inestimable amount of 30% through my 1/8 scale with the original engine and about 20 gallons through my .75. I'll stick with inefficiency and longevity rather than scratching my head at the field wondering what went wrong.[sm=confused.gif]
Old 01-01-2006, 09:31 PM
  #1211
gjeffers
gjeffers's Avatar
20 bucks for bearings and you are gonna spend a hundred or more for wasted fuel? OKDOKEY
if your engines are tuned right you can have the cake and eat it too
Old 01-01-2006, 10:49 PM
  #1212
rajul
Moderator
My Feedback: (58)
rajul's Avatar
ORIGINAL: iflynething
Right now, they are both set to the feeler that came with it. What would that make the clearance be set at .002? I think that's what it is. But that's what they are set at right now is .002, or whatever the feeler that comes with it is set at.
~Michael~
The Saito feeler is 4 mils, if my memory serves me well, plus it has burrs at the edges which might be a problem. I bought a separate 2 mils gauge for this purpose.
Old 01-02-2006, 08:27 AM
  #1213
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
According to my micrometer and my reading abilities of it, the Saito feeler guage is .00325 and the Enya feeler guage is .002. Regardles of my micrometer reading skills or lack, the Enya is thinner. When I checked my 1.25 the other day it is set precisely at the Enya feeler guage setting from the factory.
Old 01-02-2006, 02:04 PM
  #1214
iflynething
Ok, yeah thanks for that information. I don't think there is anything that clearly says in the manual what thickness the feeler is that comes with it.
My dad has some that you use for cars....alot of them, and I will use those, and set it to .002 later and see what happens. It's raining here, so might not be able to crank it up
~Michael~
Old 01-03-2006, 03:08 AM
  #1215
Ernie Misner
Ernie Misner's Avatar
Bill, are you sure that if the valves are set just a "little too tight" that it is not possible to start, run, and burn the valves or seat? I would like to think that I don't have to worry about that.
Ernie
Old 01-03-2006, 03:27 AM
  #1216
William Robison
Ernie:
The early cams without the quieting ramp run fine at zero clearance, and will not burn a valve. These are the ones I have suggested 0.0005" settings on.
The later cams with the quieting ramps are optimum at 0.04 mm clearance, that's just a hair more than 0.0015" but a 0.002" feeler can be used with almost no difference in the engine run.
Even with the quieting ramps the engines still run well at zero clearance, but the idle gets just a little rougher.
If the clearance is set to a negative vlaue the valve stands open, there's no compression, and you'll not get it to start. I've never seen a burned valve in one.
Bill.
Old 01-04-2006, 03:55 PM
  #1217
ecrt123
My Feedback: (12)
I have a Saito 72, and I replaced the head on it. I need to remove the valves and place them back in the new head. Just what is the procedure of removing and replaceing them on the new head?
Ray
Old 01-04-2006, 04:01 PM
  #1218
w8ye
My Feedback: (16)
w8ye's Avatar
I stick the head down over a sawn off broom handle so the valves will not open when I push down on the spring retainer.
I push the spring retainer down and remove the key with a scribe. Install the parts over on the new head in reverse order.
If you let one slip, the parts will go to kingdom come. I do it in a plastic bag.
Sometimes the valve will not go completely through the guide or the spring retainer will not come off because the valve stem is mushroomed. You will need to take the mushroomed metal off the valve stem.
Enjoy,
Jim
Old 01-04-2006, 05:35 PM
  #1219
Kmot
My Feedback: (24)
Kmot's Avatar
That's a slick trick, Jim! Not that I have ever had parts go flying into never-never land!
Old 01-04-2006, 05:44 PM
  #1220
ecrt123
My Feedback: (12)
I got the spring and retainer off but the valves themselves do not just come out. It is like when they go to the bottom of the valve guide in the head they get stuck. Will I have to tap them out, and tap them back in with a dowel rod?
Old 01-04-2006, 05:57 PM
  #1221
TimC
TimC's Avatar
"Sometimes the valve will not go completely through the guide or the spring retainer will not come off because the valve stem is mushroomed. You will need to take the mushroomed metal off the valve stem."
It looks like you have the problem Jim mentioned ecrt123. Your stem ends are "shroomed". Take a jeweler's file and carefully file the flared edge off. I sure wouldn't pound them through with a dowel.
Old 01-04-2006, 06:02 PM
  #1222
William Robison
Ray:
That "Catch" as the valve drops through the guide is the "...valve stem is mushroomed..." that Jim mentioned. This is a small ridge, too small to see, that develops at the upper edge of the retainer groove. You can dress it off with some very fine paper, 360-400 grit twisted around the stem, or a jeweler's file held flat against the stem. When it's all gone the valve will slide out with no effort.
Since you are replacing the cylinder you'll hurt nothing to tap them out of the old one with a punch, but if you were going to use the cylinder again you should not. When the valve is pushed through without removing the ridge it will take metal from the guide, effectively many hour's wear with just the one pass.
Bill.
Old 01-05-2006, 08:35 AM
  #1223
ecrt123
My Feedback: (12)
Thanks alot for the info. I filed the ends with sandpaper and it came right out and right into the new head.
Ray
Old 01-05-2006, 07:19 PM
  #1224
iflynething
I have yet another question:
How many turns out from all the way in are you guys running.
I'm out about 1 1/2 turns, but I know that's a little rich. I'm still breaking in my Saito!!
What are you guys running. What about the low end
~Michael~
Old 01-06-2006, 06:55 PM
  #1225
gwulle
Fellows;
I am trying to find out if the flexable exaust that fits the Saito 180 will fit my 220. I have emailed Horizon,with no response. I cannot find any dimensions on Horizan's website or my maneul as to the size of the exaust port. Any help would be greatly appreciated.
Gaines
