Welcome to Club SAITO !
Old 04-03-2009, 03:42 PM
  #14426
ddornhoffer
Default RE: Welcome to Club SAITO !
Just bought my first Saito - a 180 and going to use it in a Dynaflite Super Decathalon. Can anyone tell me if a Hyde mount is overkill for this combo and if it is, any recommendations? I look forward to reading the daily posts and thanks again
Old 04-03-2009, 05:18 PM
  #14427
sodbuster 1
sodbuster 1's Avatar
Thanks Jim and OF. Both good ideas
Old 04-03-2009, 07:14 PM
  #14428
N1EDM
I'll second what has been said... rebuilding is an option. I imagine that it will be expensive as you probably did some damage to the cylinder walls too (just a hunch) but putting a brand new top end on it would probably not be as expensive as a brand new engine. Just make sure that the cam gear and the valves are undamaged first...
Just being a busy-body,
Bob
Old 04-03-2009, 08:29 PM
  #14429
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: ddornhoffer
The soft mount is overkill
Old 04-03-2009, 08:53 PM
  #14430
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Bob93447
Question?
Is there an air seal inside the high speed needle assembly of the Saito .72? Is it replaceable? My engine, with about 100 hours of operation, now peaks at 1 turn out from fully closed. The needle is very sensitive. Any help will be appreciated.
Bob
1 turn out is somewhat normal
Close sensitive needle can be caused by the glow plug and by bad fuel or too big of prop
Saito 72's are bad about leaking between the intake manifold and the head. This will make the needle almost impossible to set
There is a o-RING inside the brass part of the needle valve that goes into the carb. It's called the spray bar and you usually have to replace the spray bar to fix it.
Old 04-03-2009, 09:03 PM
  #14431
ggraham500
ggraham500's Avatar
What is the Saito equivalent to a 30-60cc gas engine?
Old 04-03-2009, 09:12 PM
  #14432
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
That would encompass several Saito engines from the 1.80 to the 4.50. Where do you fly in F-burg? Thanks, Dave
Old 04-03-2009, 10:28 PM
  #14433
Bob93447
Thanks. Its probably the spray bar. There is almost no friction when I turn the needle valve until I reach the rachet. But I will also replace the plug just to be safe. The prop is pretty much what I started with when the engine was new, an APC 13 x 6.
Another question. When going to the Horizon Hobby site, They mention that the "baseline" prop for the saito .72 is a 13 x 8 turning at 9800 rpm. Has anyone actually seen a saito .72 turn a 13x8 at this rpm? If so, what magic prop is it?
Bob
Old 04-04-2009, 01:02 AM
  #14434
ggraham500
ggraham500's Avatar
I fly at WindWalkers RC http://www.wwrcc.com/ on a private airfield (Woodfield Air Park in Caroline county) and also at Thornburg with another club.
I have a Saito FA-180, a FA-150, a couple FA-100 and a couple FA-56. Do you think the 180 would do the job on the Wilga. I fly very scale (read that typically slow) and probably would not be towing anything.
I've played/flown the Wilga on RealFlight 3.5 and love the plane.
Gary Graham
Old 04-04-2009, 04:03 AM
  #14435
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Bob93447
Bob
I always like the 13-6 on the Saito 72. The 13-8 is too much prop for the engine
Old 04-04-2009, 05:47 AM
  #14436
Rudolph Hart
Rudolph Hart's Avatar
ORIGINAL: Bob93447
Question?
Bob
Is it possible that the needle is now very blunt at what used to be the sharp end? due to the mildly abrasive fuel with dirt particles in it.
Old 04-04-2009, 06:12 AM
  #14437
Rudolph Hart
Hello and do you find that sound to your liking mateonly saito makes it.
I like the look of the hyde mount in that it looks like you can get the engine well back close to the firewall and i need that when i add a relatively heavier engine re my extra 330.The mount is easy to understand just follow the instructions and don't worry that your spinner will wobble around a bit.I've had more movement out of glass filled nylon engine mounts,it's minimal.
Cheers mate.
ps what's the word overkill mean if you don't flesh it out?
Old 04-04-2009, 09:20 AM
  #14438
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Jim, I'm posting this here rather than in the Saito .80 thread, I received the new gasket set for my 1.15, I onlu needed the cam housing gasket. In the "Saito .80 Bearing Replacement Thread" we were discussing the timing mark on the cam and the index hole in the intake cam base. I made up a little tool to use the index hole in the cam to hold the timing while lowering the cam box into the crankcase. Bill Robison made one of all metal, I made mine from a drill bit and a piece of throttle wire guide from an ARF where I moved the throttle to the other side of the fuse. The drill bit is a perfect fit in the cam and the outside diameter of the throttle wire guide is a perfect fit in the lifter bore.
ID:	1172336   Click image for larger version
ID:	1172337   Click image for larger version
ID:	1172338   Click image for larger version
Old 04-04-2009, 11:30 AM
  #14439
42etus
42etus's Avatar
Now why didn't I think of that (Slapping forehead). [sm=thumbup.gif]
Paul
Old 04-04-2009, 08:44 PM
  #14440
wessco
My Feedback: (7)
Got a Saito .72 that keeps pushing the o-ring on the intake tube out...on the jug. What can I do to keep it in the jug? I've replaced it 2 times today. This cause deadsticks 3 times. The last time I replaced it, the engine didn't deadstick....until I ran out of fuel. Anybody ever had this problem?
Old 04-04-2009, 09:08 PM
  #14441
w8ye
My Feedback: (16)
w8ye's Avatar
You have to replace the back plate also. That is the root of the problem
Old 04-04-2009, 09:36 PM
  #14442
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Thanks Gary, I am not familiar with the Wilga, sorry. I contacted one of your Flyin Buds about the field location, I hope its closer than Waldorf.
Old 04-05-2009, 08:47 AM
  #14443
sodbuster 1
ORIGINAL: RC Specialties
sodbuster,
I would recommend an adel clamp with a hard wood block as a stand off. You can get adel clamps at the local automotive parts store but they usually have a large bolt hole. Go to a local airport and find an FBO (fixed base operator) they are the ones that sell the fuel. The aviation adels have a smaller hole. Take the muffler with you for sizing. Make sure it is anchored to the firewall well. This should solve your problem.
Jim
Found the perfect size at Home depot in the electrical department next to the wire ties!
3/4" does the trick with the 1.00 size
nice tight fit. looks good will see how it holds up at the field today.
Have finally gotten smart with losing mufflers in this plane .
drilled a 1/32" hole at the very bottom of the outlet and safety wired it to the firewall
Old 04-05-2009, 08:54 AM
  #14444
Upward
Thanks for all the good information guys, I now have my Saito FA40a back together. I know see what you mean about the guide hole in the cam. I think that I have the timing correct, the valves dont hit the piston when I turn the enging over by hand. I'll try to start her soon.....
Old 04-05-2009, 09:10 AM
  #14445
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Upward
Lets hope for the best. I'm sure you will enjoy
Old 04-05-2009, 06:57 PM
  #14446
bill3388
My Feedback: (18)
W8YE,
I live pretty close to you. Can you PM me where you bought the Wildcat 18% Premium for $12/gal?
Thank you, Bill
Old 04-05-2009, 07:33 PM
  #14447
mike early
mike early's Avatar
Once or twice a year we take advantage of this deal on Wildcat Fuels:
http://www.wildcatfuels.com/newsite/club_orders.html
We send a club member to pick them up in person. We are located a lot closer to Wildcat Fuels than most clubs....
Old 04-05-2009, 07:45 PM
  #14448
Ken6PPC
If the quality and consistency of Wildcat fuels isn't enough, the quality of the OWNER of this company encourages ME to remain a loyal customer of Wildcat.
The following is copied from the website, on this page:
http://www.wildcatfuels.com/newsite/about_us.html
Commitment and Company Philosophy
Thank you for choosing Wildcat Fuels. We are confident that Wildcat will be the obvious choice for you and your model fuel needs. We promise to always honor our commitment to disclosure of our products contents including Nitromethane, Oil content, Oil composition, and Percent volumes; because you have the right to know what your putting in your engine! We promise to always strive to produce products of uncompromising performance and quality.Our people are dedicated to delivering products that consistently exceed our customers' expectations and we are proud to be part of a team in which earning our customers' loyalty is our #1 priority. We at Wildcat will always strive to do our best to honor God, serve our customers, and help you to have fun. Quality is our commitment not our slogan. In a day where the truth is determined by the quantity and quality of spin, we will strive to present the truth in a straight forward and reliable manner.
Our company philosophy is simple, "Serve God with a smile, love people......they're his kids, and have fun doing time on planet earth". I hope we can help with either one.
In this day and age, honesty and integrity is a rare commodity. So much so, we tend to become suspicious when we encounter it! I believe Jerry Conley is the real deal....
Old 04-05-2009, 07:46 PM
  #14449
jdkxtreme
I am getting ready to purchase a few cases of fuel..over the winter I ended up wit a few saitos..I usually ran 15% plane....should i run 15% heli fuel for the extra oil? the 2 strokes will run fine on either..
Old 04-05-2009, 08:02 PM
  #14450
w8ye
My Feedback: (16)
w8ye's Avatar
Saitos like to have a little castor oil in their fuel
