Welcome to Club SAITO !
Old 07-18-2010, 06:07 AM
  #17926
Rudolph Hart
Rudolph Hart's Avatar
Default RE: Welcome to Club SAITO !
Seems like it's all mememe at the mo so can't be to bad(for me)took the 182 to the club today and bench ran it again.Second run last monday peaked @ 7400 and with no needle changes today she pulls 8200 and what a sound specially idled back,i'm in heaven
Old 07-18-2010, 02:46 PM
  #17927
w8ye
My Feedback: (16)
w8ye's Avatar
I'm trying to remember but I'm thinking my 182 did about 8300 with a APC 16 X 8
Old 07-20-2010, 10:48 AM
  #17928
Rudolph Hart
What were you flying it in?
Old 07-21-2010, 09:41 PM
  #17929
Jimmy Hoffa
Jimmy Hoffa's Avatar
This question was asked one page back but the answer was unclear to me. Does the slit in the spray bar go towards the atmosphere or engine?
Phillip
Old 07-21-2010, 10:07 PM
  #17930
rcdude7
My Feedback: (264)
ORIGINAL: Jimmy Hoffa
Phillip
Always towards the engine.
Old 07-21-2010, 11:07 PM
  #17931
We3R/C
Hello again, Anyone tried Xoar "sword" in 18x6 on a Saito 180? Gimme some numbers!!
Old 07-22-2010, 06:50 AM
  #17932
Jimmy Hoffa
ORIGINAL: rcdude7
Ok. I was wondering because when it's in that position the carb fuel inlet doesn't line up with the hole in the spray bar. There is a channel for fuel flow around the circumference but in the past I thought the spray bar hole should be directly under the fuel line nipple.
I'm pretty sure the Viton O-ring goes next to the head. My new gasket set and intake manifold did not come with that metal washer that goes next to the Viton ring. Is it necessary?
Phillip
Old 07-22-2010, 06:56 AM
  #17933
w8ye
My Feedback: (16)
w8ye's Avatar
All my Saito's have that metal washer on the intake manifold
Old 07-22-2010, 08:29 AM
  #17934
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Dead center up toward the engine.
Old 07-22-2010, 08:32 AM
  #17935
Jimmy Hoffa
Found it in my Saito parts bin. It is included with the engine gasket set.
Phillip
Old 07-22-2010, 08:57 AM
  #17936
Jimmy Hoffa
ORIGINAL: Hobbsy
Got it.
Phillip
Old 07-22-2010, 09:16 AM
  #17937
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Jim, my .62 is a bit unusual in that it has a black washer on the intake O-ring and the .40a has a rubber sleeve around the pipe which is cast aluminum.
ID:	1471676   Click image for larger version
ID:	1471677   Click image for larger version
Old 07-22-2010, 09:46 AM
  #17938
blw
blw's Avatar
I like the rubber sleeve idea.
Old 07-22-2010, 09:55 AM
  #17939
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I'll have to check my .30, I think it has a similar cast intake pipe but with an O-ring.
Old 07-22-2010, 10:08 AM
  #17940
w8ye
My Feedback: (16)
w8ye's Avatar
Its been about 4 yrs since I had one of my 30's apart
I never noticed the washer being black on my 62GK's I use one of them all the time and the other is NIB
Old 07-22-2010, 10:15 AM
  #17941
w8ye
My Feedback: (16)
w8ye's Avatar
I've had a Saito 82A about 4 yrs. I decided to make a 82B out of it.
I bought
Back plate
Crankcase
Cam cover
Carb screw set
Cam pivot shaft
I had to steal a cam cover gasket from my Saito FG20 collection and I had to make a gasket for the back plate as Horizon doesn't have gaskets yet.
I made the back plate gasket from the cover flap of the package that the back plate came in. I cut the inside circle and slipped it over the back plate and then mounted the back plate and trimed off the outside. You need a gasket back there to keep the cam cover from rubbing on the crankshaft pin.
After getting it together I ran the engine on the test bench and it runs just as good as it did before I changed everything.
Old 07-22-2010, 11:35 AM
  #17942
ZachB10
My Feedback: (9)
Just picked up a Saito FA-80 golden knight for an ultra stick 60.  Can't wait to fire it up
Old 07-22-2010, 11:36 AM
  #17943
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Jim, here's the .30 arrangement.
Jim et al, Lynda is back in the hospital, one of her kidneys stopped working and loaded her up with uric acid causing violent convulsions and near comotose. They got here awake yesterday but she is still very weak.
Old 07-22-2010, 12:23 PM
  #17944
Rudolph Hart
ORIGINAL: We3R/C
Hello again, Anyone tried Xoar ''sword'' in 18x6 on a Saito 180? Gimme some numbers!!
Hello yes i can you are saito club member number #560
ORIGINAL: We3R/C
ORIGINAL: We3R/C
Old 07-22-2010, 12:42 PM
  #17945
spaceworm
Oh, does he need to be Club Saito member before someone will give him rpms for the prop/engine combination he has? Just curious.
Richard
Old 07-22-2010, 01:22 PM
  #17946
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: ZachB10
Good luck with the Saito 80, It will be great on the Ultra Stick 60
Old 07-22-2010, 01:38 PM
  #17947
w8ye
My Feedback: (16)
w8ye's Avatar
ORIGINAL: Old Fart
ORIGINAL: We3R/C
ORIGINAL: We3R/C
ORIGINAL: We3R/C
Saito 180 performance with various 18 X 6 props
APC 18x6W, 8900 RPM, 20/20
APC 18X6W 30 heli slimline pitts , 9100rpm
MenzS 18x6 and 10% nitro 8600rpm
20/20 fuel, 18X6 Mezjlik 8500
Wildcat 15% and MA classic 18x6 turned 8600RPM
Wildcat 15%, 18%synth/castor blend
MA Classic 18x6 8800 rpm
8670rpm with a Xoar 18x6 Turbo Header
APC 18x6w @8400rpm and 17x6@9400rpm and fuel is 10% nitro
APC 18X6W, 10 % nitro : 8900 rpm
Old 07-22-2010, 02:46 PM
  #17948
ZachB10
My Feedback: (9)
ORIGINAL: w8ye
ORIGINAL: ZachB10
Thanks! Hoping it works well. It should look cool too (Ithink) as there's no cowl on the plane. Always liked the golden knights but don't see the point if you cover up the engine. I'll be using a gold spinner prop nut too.
So what's up with the club? What's involved ?
Old 07-22-2010, 02:51 PM
  #17949
w8ye
My Feedback: (16)
w8ye's Avatar
The club number gives a member certain endowed inalienable bragging rights?
Request a number if you own a Saito and BLW will be along to to give you the next number on his list.
Old 07-22-2010, 03:49 PM
  #17950
Tom Jones
Tom Jones's Avatar
Hobbsy, Is Lynda your wife? Hope she is getting better. My Prayers are with her for a complete recovery, God willing. Take care Tom
