Reload this Page >
Tamjets 1/6 Scale F-16, made by Feibao
Old 04-11-2020, 06:42 AM
frankle951
My Feedback: (35)
frankle951's Avatar
Well, got a little done on the retract, the mains are bolted in, took a lot of dremel work, but there not hitting the side, now I'm cutting the slots for nose gear, here some pics.
Old 04-16-2020, 03:41 PM
frankle951
My Feedback: (35)
frankle951's Avatar
Ok, got a lot more done, on the F-16, finish up the back half section, that hold 5 servo, two elevators, two ailerons and one rudder, the rudder was the hardest to finish, with the servo inside the rudder, the ailerons servo took some time, but it's done, once I finish up the nose gear, I can set it on the wheels and bolt the two section together. Then come bolting the turbine in place. Getting pretty close to a taxi run.
Old 04-16-2020, 03:47 PM
frankle951
My Feedback: (35)
frankle951's Avatar
I think my biggest challenge is going to be the gear doors, I may use a Linear servo, but to make it easy, air cylinder.
Old 04-21-2020, 11:56 AM
frankle951
My Feedback: (35)
frankle951's Avatar
Well, all servo wire ran, just bolted the turbine in, looking at the wires, box, ic board, would love to put everything up front for weight, but the cable are to short, I hate to add weight up front.
Old 04-22-2020, 09:04 AM
Bob_B
Bob_B's Avatar
Frank, that is an interesting way to control the NG Steering!
Old 04-22-2020, 09:40 AM
  #31
frankle951
My Feedback: (35)
frankle951's Avatar
Sorry bob, don't understand NG ??
Old 04-22-2020, 09:41 AM
  #32
Bob_B
Bob_B's Avatar
Nose Gear.
Old 04-22-2020, 05:12 PM
  #33
frankle951
My Feedback: (35)
frankle951's Avatar
Ok bob, it went over my head, but it's almost ready to taxi around.
Old 04-23-2020, 09:54 AM
  #34
frankle951
My Feedback: (35)
frankle951's Avatar
Well, it's raining outside, maybe I can get more done today, just received my two large Robert's air tanks, I can install them in the fuselage today and run the lines, I have one brake line to run, still trying to figure out where to put the center fuel tank, I know it need to be near the CG line, here some pics.
Old 04-23-2020, 12:32 PM
  #35
frankle951
My Feedback: (35)
frankle951's Avatar
Ok, I have been looking at ppg paint color, I think I like the tiger meet scheme, not really sure yet.
Old 04-23-2020, 12:34 PM
  #36
frankle951
My Feedback: (35)
frankle951's Avatar
Ok, air tanks installed.
Old 04-26-2020, 10:11 AM
  #37
frankle951
My Feedback: (35)
frankle951's Avatar
Wow, getting there, all wires, fuel lines, cable ran, need to run retract air lines from the mains, to the front, then I can set the three tanks in the fuselage, learn the throttle to the ecu, spool up the turbine, test solenoid valves, ran the fuel pump, my ix12 spekrum radio, has a sequencer built in, may use it, now to cleanup the front board.
Old 04-30-2020, 05:49 AM
  #38
frankle951
My Feedback: (35)
frankle951's Avatar
Time to cleanup the front board, I remove the regulator, to make room for the uat tank, and forgot, the steering servo is 6volt, well I smell smoke, going to remove the nose gear to replace the servo, with a 7.4 hitec 7954sh servo, well the board is starting to look better.
Old 05-04-2020, 02:10 PM
  #39
frankle951
My Feedback: (35)
frankle951's Avatar
Ok, guys the main retracts are not locking in place, to the gear solid ?, I see other manufacturers use a air cylinder to lock there ?, I sent Catherine at feibao a email asking how the bar Supposed to lock on it's own, the bar do have plate, I guess I can move it back or forward, to see if that help to lock the bar.
Old 05-05-2020, 08:26 AM
  #40
FalconWings
My Feedback: (57)
FalconWings's Avatar
Please, don't TigerScheme! 🤣🤣
Old 05-05-2020, 02:33 PM
  #41
frankle951
My Feedback: (35)
frankle951's Avatar
Sorry, I love the tiger meet, every time I go to a jet meet, you see the same old military scheme, I'm not much on military color.
Old 05-09-2020, 01:49 PM
  #42
frankle951
My Feedback: (35)
frankle951's Avatar
Well got a lot done, was able to start up the Jetcat P160se and taxi around, no leaks, all three tank drain perfect, figure out the locking bars on the main retract, well back to work.
Old 05-09-2020, 02:49 PM
  #43
causeitflies
causeitflies's Avatar
So did you figure out the locking bars or still have to do that?
Old 05-09-2020, 06:36 PM
  #44
frankle951
My Feedback: (35)
frankle951's Avatar
Yes, me and my friend larry, flip the f-16 over on a stand and start playing with the locking bar, moving it forward and back, it really lock in place when moving the gear forward, and moving the plates forward, one main gear has about 2mm more play then the other side, I guess I can live with that.
Old 05-18-2020, 09:46 AM
  #45
causeitflies
Requested pics. Are you using leading edge flaps?
Old 05-18-2020, 12:40 PM
  #46
frankle951
My Feedback: (35)
frankle951's Avatar
Yes, I'm going to use the leading edge, thanks for the pics.
Old 05-19-2020, 02:25 PM
  #47
frankle951
My Feedback: (35)
frankle951's Avatar
Well, maybe not, might just use a better servo arm, the one I made was not accurate, my friend has a 3D cutter, and he made a Prototype of what I need, a lot more better made, going to use a 20mm round servo arm, with a piece of hard wood mill down, should be strong, found out, always check and tighten all screw on your retract, I found 5 screws loose, I lock tight them down.
Old 06-03-2020, 05:02 AM
  #48
meps
My Feedback: (10)
I was looking over my nosegear and noticed that the aluminum steering arm is not secured to the nylon pinion gear that turns the strut left and right when extended, as well as rotate the gear when retracting it. The arm is kind of slid over the nylon gear with nothing preventing it from "slipping" when the steering servo moves the arm. Is your gear the same way? I contacted Catherine about it but haven't gotten an answer other than her colleagues told her that there's no correlation between the nylon gear and aluminum steering arm.
Steve
Old 06-03-2020, 05:05 AM
  #49
frankle951
My Feedback: (35)
frankle951's Avatar
I will look and take pictures.
Old 06-06-2020, 02:02 AM
  #50
Ceeray
How much was the retract set?
