Foamie jet for X45/K45 ?
#251
Recently inspected (for Australian certification) a Freewing A-10 with two K-45's fitted.
Flew great but the paperwork is noted as speed limited as the factory servos, linkages & horns are probably adequate at best.
#252
I made my own custom pipe for the F22, detailed earlier in this thread. The pipe is in two parts, forming a oval on the exit, this allows it to fit within the foam thrust cavity. I also found that I had a slight increase in thrust with my pipe from the X45, I'm guessing that this is due to the convergent to divergent design. This style of pipe was pioneered by Mike Wren many years ago, when he proved that the right pipe design could increase a turbine thrust level slightly, and in my case I measured just under 11lbs of thrust.
#254
My F22 taking off with the centre burner lights at full power.
I'm not sure whose photo this is, but I copied them when doing my research on the turbine conversion. Thanks to the original owner of the photo.
Another type of engine installation, no need for a pipe.
Another home made pipe for my FW L39 conversion.
The Coke cup makes a perfect inlet funnel, cheap at $5 each!
concept, and to my surprise, it worked extremely well, plus gave me the advantage of being able to put centre burner lights either side of the thrust tube.
#256
Wow, thanks Gary, I should have known it was yours by the high quality of the installation!! I was just trying to show that there are multiple ways of converting this amazing jet to turbine.
#258
My Feedback: (20)
Foam glue, epoxy, craft glues, and wood glues will all work on the foam.
I use light weight water base wall spackle for filler. Spread it on cracks and let dry and sand smooth.
Almost any kind of paint will work on the foam. I use latex house paint tinted to match in sample size jars. Craft paint will work also. I usually coat the whole plane with water base polyurethane to seal and protect the foam surface. It makes cleaning easier.
#259
What are you repairing? Show us some photos of our project.
#260
My Feedback: (20)
All the items I mentioned above will work well on the F-22. I've used them all on many Freewing foamies. Here we can take a part of the plane to the paint stores and get a latex paint color match mixed in a small jar. It is perfect for painting foamies. The light weight spackle is not the heavy plaster stuff but much lighter and sands easy. Just glue, patch, sand, and paint. I also recommend the water base polyurethane top coat.
#261
Finally because i crashed my plane, i ordered a new one but also i made a new pipe.I respected what said one of you regarding transformation from circle to oval to have the same area, and this is how it looks. I have to say that before ending pipe i will use a carbon fiber support. At the moment the pipe, and soon the entire new plane.
#264
So i almost finished the plane. I put the pipe an i didn't need to cut the plane, only the inside parts ..That pipe is lighter that the bifurcated with 50 gr. Inside the plane i put some ceramic paper(2 mm thickness), resist at 1200 gr heat and also aluminum tape. I have to cut the support for the pipe(carbon fiber), to remains fixe and that's all. I also painted in black to see the difference between the two faces and be more visible as a pilot.
Viper1GJ (04-29-2024)
#267
And the movie with one of the flights..it is a big difference in matter of power and consumption, with this pipe and 1 l tank, i flew around 10 min..
https://www.youtube.com/watch?v=ya6k1HyNVHk
