Foamie jet for X45/K45 ?
#176
Thanks guys, probably about another week or to before she's ready, but will probably go like a bat out of hell with 10lbs of thrust!! I can't get the flaps to reverse running through the control box, so will have to figure out the wiring coming from the wing and bypass and go straight to the RX.
#177
#179
Greg, thanks for the info. If this unit works as well as I'm thinking it will I'm going to retrofit my other micro turbine jets with them. Has anyone tried this unit on a larger jet with electric brakes? -Tom
PREACHHAMES (02-18-2021)
#183
My Feedback: (58)
You got it! Hopefully you'll see it all ready to fly in person next Saturday
Yes the tank is by Keith . . . great design.
I weighed the 6S power system (fan unit, motor, ESC, & wiring) and it came out to 1.35 lbs. the turbine sits in the same spot and only weighs 1.03 lbs
Greg
Greg
Jared (02-21-2021)
PREACHHAMES (02-19-2021)
#190
#191
My Feedback: (58)
Thanks for the heads up Ducmoz . . . still have to make sure the C/G is going to be good once my pipe arrives (more than likely Monday).
I'm also going to get the solid on/off valve and fuel line reducers (6mm to 4mm and 4mm to 3mm).
Greg
Greg
#193
Hi Greg, no problem. A successful turbine conversion means an additional jet pilot for our community. Now please also check your UAT. I have not seen that one before but I am mostly sure that the nipples need to be on the top and might cause issues if installed side ways. I am sure the supplier can help on that also.
‘Thanks
Behzad
‘Thanks
Behzad
#194
My Feedback: (58)
Behzad,
The UAT is the same one Viper1GJ used in his Phantom (see post #47).
https://www.modelaviationproducts.co...-accessories/6
It is 2 oz. and since the fuel is fed to the pump from the very center of the unit, mounting orientation should not matter (vertical, horizontal, angled, etc.).
Greg
Greg
PREACHHAMES (02-22-2021)
#198
Looks awesome! I have mounted that same UAT with a K30 in a Habu32 and it works fine on it's side. As someone said here though, make sure you tilt the airframe when you are fueling to make sure you get the air out of the UAT. Also, on your safety wire, you will want to make sure you wrap the wire around twice before twisting it, that way you have even contact all the way around the tube. Can't wait to see video of this one! - Tom
#199
My Feedback: (58)
Thanks Tom,
I flew her three times on Saturday adjusting the CG back after the first flight.
Second of all, it turns out my pipe was too close to the turbine and was not producing full thrust at max RPM.
Also I'm going to have to trim off some of the back of the fuel cell so I can slide it further aft . . . more centered over the CG.
We should be golden after that!
A special thank you to Vipet1GJ for his expertise and assistance on the Phantom Saturday.
Greg
Greg
Viper1GJ (03-02-2021)
#200
Question for those of you using the AG63 gyro brake controller. I installed one in my FW T33 powered by Xicoy X45. I went through the setup and everything seemed like it was working correctly. On my first landing I hit the brakes and the whole jet immediately yawed 90 degrees to the right and slid down the runway (sideways). This is exactly the behavior I was hoping this device would prevent, so I'm looking for any advice on what to do next. Immediately after sliding down the runway sideways, I did some high speed taxing (almost fast enough to rotate) back and forth and the brakes stopped the jet perfectly straight every time. Any ideas? Thanks, Tom
