Reload this Page >
F-16XL ARF by Global Knight Models from Global Jet Club
Old 07-23-2021, 01:53 PM
  #326
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Bob,
I thought mine was working correctly. I think I was at 100% but will check. I have not got my nose gear back in yet. I will let you know.
I think I remember reading somewhere that Jeti travel was more than other radio systems. Don't remember the numbers though.
Gary
Old 07-23-2021, 01:55 PM
  #327
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Cool video from Josh
Old 07-23-2021, 02:10 PM
  #328
Dansy
My Feedback: (53)
Dansy's Avatar
Originally Posted by Viper1GJ
Bob,
Gary
100% on Spektrum is actually 80% on Jeti
Old 07-23-2021, 02:21 PM
  #329
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
That may be what the problem is.
Old 07-23-2021, 02:31 PM
  #330
Dansy
My Feedback: (53)
Dansy's Avatar
I found that out in 2012-13 when I switch from my JR12x to Jeti……everything was hitting the stop….I made some enquires and found 100=80%
Old 07-23-2021, 02:34 PM
  #331
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Good info to know. Thanks.
G
Old 07-23-2021, 03:09 PM
  #332
Bob_B
Bob_B's Avatar
As an example if driving a Aura Gyro you reduce the Tx output to 80% to have the same travel that a Spectrum or Futaba tx. Since most in China use Futaba. And where the Assan is made. Im thinking having 100% on Jeti is beyond the range that the Assan recognizes for the programming steps.
otherwise it works fine.
Old 07-23-2021, 05:03 PM
  #333
Dansy
My Feedback: (53)
Dansy's Avatar
I used the 80% only for the servo’s if I get that I’m happy…but I still try to get 100% just when I was retrofitting planes after moving to Jeti, I was making my plane sensitive and hitting the stop…for the turbine, retract ect I always set 100%…..never actually taught about that….and they all work fine…
Old 07-24-2021, 08:36 AM
  #334
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Gary have you setup the Ag 63 installed in this model? I too fly Jeti and installed one on my JP gear equipped model. I was not able to get the auto config feature work.
I have the unit working correctly and helped a friend do the same. In order to have the gyro move the steering servo to compensate correctly he had to reduce the end points to 80%.
look forward to your response.
Hi Bob,
I got my nose gear reinstalled today. I checked my NG settings and I had +/- 100% set from the initial setup. It took the first programming attempt and was working correctly back when I first did it. I have now reduced my throw limits to +/- 80% and rechecked it. The gyro is still commanding the correct direction for yaw steering corrections. I roll tested it several times on the shop floor and it rolls dead straight. That's a good sign as I know my nose wheel is not perfectly straight as I just eyeballed it close. So I am assuming the gyro is providing correct yaw steering commands to keep the roll straight. It seems to have a lot of gain when doing the nose swing test but I understand that is normal. I hope to test fly next week. My brakes are now much stronger on the 3S battery. I'll report back after flying.
Gary
Old 07-24-2021, 11:53 AM
  #335
Bob_B
Bob_B's Avatar
Thanks for checking Gary. Yes the steering gyro will keep it going perfect straight
Old 07-27-2021, 05:23 PM
  #336
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
My F-16 XL Went Flying Again!
Preflight checklist. Jet flew well and validated all the repair work and new equipment installs. Everything worked well including the airspeed sensor. Unfortunately I had to cut the day short after only one flight after I got a call for an emergency in our neighborhood.
WIth the turbine started and ready to taxi, my buddy says "Get a picture!" Ok done!. I taxied to the takeoff position and I was amazed at how straight the jet taxied. The steering gyro really works well. Takeoff required very little steering correction. I was very happy with it.
drfred58809 (07-29-2021)
Old 07-27-2021, 05:26 PM
  #337
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Takeoff tracking was great. Current CG seems to be pretty good. I will fine tune it after I get some more flights.
The following 2 users liked this post by Viper1GJ:
drfred58809 (07-28-2021), mongo (08-09-2021)
Old 07-27-2021, 05:35 PM
  #338
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Got lucky on landing. I lost sight during round out and flare due to the low light from the grey overcast, dark background in trees, and sunglasses. As I have said many times, "I'd rather be lucky than good any day!" Anyway we survived to fight again. The brakes are now much more effective on 3S battery power. The jet flies great and I'm looking forward to flying it again when I can get several sorties back to back.
The following 3 users liked this post by Viper1GJ:
BadBill (07-29-2021), drfred58809 (07-29-2021), patf (07-28-2021)
Old 07-29-2021, 04:06 PM
  #339
mongo
My Feedback: (15)
mongo's Avatar
yall that have flown one of these, what thoughts ya got on a 140 size turbine.
Old 07-29-2021, 04:17 PM
  #340
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
IMO it would be marginal. I'm sure it would fly but vertical would be limited. On pavement it would roll a long way before lift off and on grass at my field it would be scary with trees at both ends. I would suggest a 160N minimum, better yet 180N or up. Just my opinion.
Gary
Old 07-29-2021, 05:35 PM
  #341
jf16crew
The following 2 users liked this post by jf16crew:
BadBill (07-30-2021), Viper1GJ (07-30-2021)
Old 07-30-2021, 07:33 PM
  #342
jf16crew
Default Wing strength
I'd like to address the major over reaction about the wing mounts on this jet . I have 10hrs on this airframe now and around 60 flights I don't not fly it gental. My jet is unmodified and still rock solid. In fact I am about to order a TV pipe for it ! . So for the guys who where stating this is an unsafe aircraft with out any hands on experience . Please stick to your day jobs .
Old 08-09-2021, 09:30 PM
  #343
mongo
My Feedback: (15)
mongo's Avatar
i have a sw 190 for mine, but i also have a sw 140, that i am considering trying, after getting it dialed in with the 190. just so i can have the options later.
add in
every place i fly, is pavement. used to fly from grass decades ago, in the early 60s, when we first did a runway at benbrook for the fort worth thunderbirds club. i cant even imagine trying to fly from grass anymore, at least what pass for grass out here in the wild west.
usually just getting off the paved surface here will rip the gear out of a taxiing model, let alone one moving fast.
Viper1GJ (08-10-2021)
Old 08-10-2021, 08:00 AM
  #344
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
I think the 190 will be great. Interested to see how a 140 would do.
I flew at Thunderbirds Benbrook from 93-96 when I was stationed at Lockheed FW Carswell. I have never seen the new site except in photos.
Gary
Old 08-10-2021, 10:18 AM
  #345
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
It’s a nice field but old site had better views. New site is in a box cutout etc with north end open towards lake.
Old 08-11-2021, 03:49 PM
  #346
Afterburners
Afterburners's Avatar
This popped up on my YT feed. Thought it might be of interest to some in this thread
Old 08-14-2021, 01:26 PM
  #347
tmgreen64
I have finally gotten all the parts and pieces I need to finish, My fuel tank came in todays mail. I tried to make one but it did not turn out so good, very heavy. So a friend made one for me, Raiko Potter, he was very busy with work and a new house. But he took time to make a tank for me. Now that he has a mold other can be made must faster. So with a hurrican on it way I will lock my self in the garage and work on jets.
raiko email: [email protected]
Terry G
raikodzigns (08-16-2021)
Old 08-14-2021, 03:41 PM
  #348
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Tank looks great! Keep posting your progress.
Old 08-14-2021, 03:52 PM
  #349
Bob_B
Bob_B's Avatar
I have one of his tanks for my second Flex Jet Pro. Very nicely made!
Old 09-01-2021, 11:47 AM
  #350
tmgreen64
Almost there!, Got some work done in the last few days because of the rain, hope all lmy firends in the path of Ida are safe. Just need to do some touch up paint and a lot of adjustments. Just a WAG it should be arount 35# dry. Going to replace the main gear door servos, they will not hold end points, and jump around on opeing and closing the doors, the doors do not fit up against the fuse that great so I am going to add some magnets to keep the door tight.
The following 2 users liked this post by tmgreen64:
mongo (09-01-2021), Viper1GJ (09-01-2021)
