Heng Long FPV "System"
Hmmm, looks to be a 2.4GHz system though I can't really tell by the antenna length from the picture. Most likely it is wifi fpv as that is much easier to get past FCC regulations.
Edit: also best not to engage the troll, he is most likely just looking for posts.
They call it wifi and show it being received on a cell phone, so I think you are correct. BUT the VTX does look similar to ones I have that are 5.8G.
Just for reference the cam I speak of is here: https://www.getfpv.com/caddx-beetle-...-5-8g-vtx.html (there are lots of clones out but the beetle I found was really good for overall light handling) and you can either use a 5V regulator or find one that uses Vbat and use straight battery voltage. If you add a cheap drone board you can even do camera switching too
I agree. Though I posted the link I was in no way saying I've used it or would recommend it. On my planes and quads I am using Shark Byte with head tracking.
On my tank I'll be using a small AIO like you linked as I have a half dozen or more of them, some 25mW, some 200, some that I can flip the image, some that have a cable between the camera and VTX, some with a dipole and some with a RHCP, and some work off a 1S LiPo while others are 5V or higher.
I'll probably use a 25/ 200mW AIO with a dipole that works off a 1S that I have a ton of. One has a foam shell I can easily pain to match and glue a magnet to the bottom. I'll use a 7" Eachine monitor but haven't figured out my mounting yet.
#31
It looks very similar to one I bought from them, similarly marketed and priced. The one I bought was indeed wifi, to run on a phone. It was moderately laggy and it tended to overheat and shut itself down in summer weather. That is summer in Maine weather.
The one thing it had going for it was the very small, flexibly connected camera. It could easily be placed to look out through existent openings on the tank.
I made an interesting discovery playing around with it. While the idea of an fpv view from inside the tank sounded good to me, I found it to be disappointing. It made running the tank too much like a video game. I discovered that what I really like about rc tanks is watching them in action as I run them. Being outside watching my tank deal with obstacles, etc was the fun part for me. The last thing I wanted was to be staring at a screen. Naturally this is just my personal take on it and others may find scale fpv tanking to be enthralling. For me though making this self discovery for the price of the product was worth it.
