3W Bearcat with Moki 300
mitchilito (06-13-2023)
#377
My Feedback: (7)
Well, I can't believe it. After almost SEVEN YEARS I'm finally in final assembly! Today I installed the rudder and the canopy latch. Both came out fantastically. I did all this prep work so long ago I honestly can't remember! I can say this: it's going to progress VERY quickly now because I have long since done ALL the hard stuff.
EDIT: Can I beat Detlef to maiden flight????
#378
Hi Mitch,
I am happy with you about your great progress.
In Summertime, I myself am not very often in my workshop, and therefore there only slow progress on final assembly here.
Do you already know where exactly you will put the CG?
#381
Thats where it would be due to my simple calculation.
But for some reason, the BC should be flown with a more forward CG
I gave all my old documetation away when I sold the BC I years ago, really too bad.
I think 3W recommends 190 mm and I flew mine between 200 and 210. went perfect.
Of course a little depending on Pilots taste
#382
My Feedback: (7)
I have a Xicoy balance machine which I can't wait to put into use once again.
#383
Using this CG calculator program will tell you where the CG should be located. It's simple to use and it has never failed me especially when doing a maiden flight. https://rcplanes.online/cg_calc.htm
mitchilito (07-01-2023)
#384
Mitch,
I forgot that you have clipped wings.
I would start with 200, I can truly confirm that this works very well.
You can alway go a little aft if you fine trim the Cat later.
Funny, I also purchased the Yicoy scales last week. A friend has one and we weighed my Trojan and T-33 the other week.
I liked it so much that I ordered a Set ( 100 kg Version as I also habe some heavies as well)
#385
My Feedback: (7)
Mitch,
#386
Funny how parallel our final turns out.
First wing is fully functional
#387
My Feedback: (7)
Total weight - minus radio, air equipment and gas tank: 48.53 pounds. I would guess final weight will be very close to 53 pounds.
EDIT: Minus cradle total is 47 lbs even YAAYYY!
Here is almost everything fuselage related. Tail is complete with servos and tail wheel installed . I picked it up on the wing tube (with the cowl in the proper place) and it balanced dead on 200mm!! I could NOT believe it and. . . . .
. . . . here is what all that weighs
I stacked everything else I could find onto the sales (the landing gear are under there) and. . . .
. . . .here's what that weighs.
Whoops, forgot the wing tube. . . .
. . .It's not light
Also forgot the gear doors. . . .
. . .which weighs this much. Bottom line: she weighs a grand total of 48.53. I'm pretty happy with that figure. Especially since the balance is fantastic.
EDIT: I forgot to subtract the cradle which weighs 1.53 lbs. Actual total 🟰 47.0 lbs. Yaayyyyy!!
#389
Hey Mitch,
absolutely no question that your Bearcat is a wonderful piece of art, second to none (!!)
I am not surprised by your weighing result. VERY close to mine, what else..
With the 300, everything is totally easy concerning CG. Put everything where you like it best and it fits perfect.
My wing is ready.
8 kilogram Grumman Goodies including Servos & tube
I am sure your clipped wing is lighter
My wing is ready.
#393
gow589 (07-04-2023)
gow589 (07-06-2023)
#397
[QUOTE=Detlef Kunkel;12777115]
Absolutely stunning - and so different :-)
At the moment, my progress is pretty nice.
Wing - done
tail - done
RC installation - 65,34 %
Tank & pump - done
4 cowling flaps - done
This weekend, the engine installation is planned.
I borrowed 2 pushrods to a friend, he lost them due to sticking valves. Old story. You MUST take care of that and lubricate them very frequently, causing the enging room to look VERY scale after 2 flights :-)
New ones came today from Airworld. So the 300 is shortly complete again.
I really want to see how she looks on her long legs, and that is really close ahead
Wing - done
tail - done
Tank & pump - done
#398
I think I posted this before? not sure
When I took off the heads for the second time ( reaming the guides for more play) I machined lubrication tubes into the exhaust guides.
A machine job, no free-hand
Only exhaust is needing this, inlet lubricates itself from the oil gasoline mixture.
Every 2 flights I give it a (central = red arrow) push with teflon lubricant. It works and saves uncounted disassemblies of prop and cowling. 3 lost pushrods and 2 bent ones were enough to make this solution reasonable.
#399
My Feedback: (7)
One question: what kind of red flexible tubing is that that will take the heat of that cylinder head, especially on the exhaust side? I would think only silicon would take that kind of heat.
#400
Thats only a simple pneumatic gear tube ( 3 mm outer dia) that I use for my retracts.
Well air cooled, never failed.
Silicone likes to fail sometimes if used for certain mineralic oils . As always- tests will make you cleverer :-)
BTW
funny what "experts" are discussing seeing this red line system.
Even "he goes turbocharging the engine " was one of the estimations :-)
Simply great fun :-)
